Reverse polarity DC motor cyclic timer
dhruvpatel00764
Joined Apr 28, 2024
20
i want to create DC Motor Reverse Polarity Cyclic Timer Switch, here i post some pictures that uses 555 timer ic.
can anyone make working diagram from pictures? thank you.s-l1600.jpgs-l1600 (1).jpg
boostbuck
Joined Oct 5, 2017
1,067
It appears from your photograph that the two trimpots are 2.2 Meg, but the other component values are hidden. If the circuit is supplied by 12V then R1 would be about 1K0. C2 around 1n0. C1 will be determined by the range of timing you require. D1 a 1N4007 it appears.
FYI I note an error in my sketch - pin 2 and 6 of the 555 should be connected for astable mode, per section 7.4.2 in this datasheet (which also has tables to help you determine value of C1).
LowQCab
Joined Nov 6, 2012
5,102
A Relay is a mechanical device, and is subject to wear,
and has a finite number of operations that it is designed to endure.
If this project is intended to run continuously,
it will eventually fail, or become intermittent,
especially if the Relay is not extremely over-specified for
the proposed Load that will be expected to withstand.
Reversing the polarity on a running Motor will cause a tremendous Current-Spike
which will quickly destroy the Relay's Contacts, and the Brushes inside the Motor.
More specific information is required regarding what this project is supposed to accomplish overall,
how reliable it must be,
the specifications of the Motor that will be switched,
exactly how long between reversals,
the mechanical-Load that the Motor is moving,
etc., etc., etc..
dhruvpatel00764
Joined Apr 28, 2024
20
etc., etc., etc..
i want to create rotating device using 755 motor,
timing value in seconds : start>10 sec forward>2-3 sec delay>10 sec reverse>2-3 sec delay>start the cycle again.
in above pictures that i posted, there is two pots to make adjustment on forward and reverse time.
hope you understand, sorry for my bad english.
LowQCab
Joined Nov 6, 2012
5,102
What is the "Locked-Rotor-Amps" of the 755-Motor at the Voltage that You intend to use ?
Please describe, in detail,
( pictures would be the best ),
the Mechanical-Load that the Motor will be turning.
Will the Motor be attached to ...............
a Gear-Box ?, a Fan/Propeller ?, Wheels on a small car ?, Belt and Pulleys ?
Does the Motor need to be stopped before hitting an object,
or reaching "end-of-travel" on a rail ?, or, is it driving a "Linear-Actuator" ?, or a "Screw" ?
ALL OF THE DETAILS ARE IMPORTANT,
for a project that will perform as expected, and have reliable-operation.
MisterBill2
Joined Jan 23, 2018
28,510
The photo of the component side is so very poor and dark that nothing can be read or even seen clearly. And while the lifetime of relays is far from infinite, if the relay is used well within limits it should last for a long time.
dhruvpatel00764
Joined Apr 28, 2024
20
i want to create like this on small scale. it consumes 20W of power. i would like to use with 12v power supply.
LowQCab
Joined Nov 6, 2012
5,102
The 755-Motor that You have chosen is a high-quality, very HIGH-RPM-Motor.
It would be a better plan to use a "Gear-Motor", with a much lower RPM-range,
probably less than ~1000-RPM @~12-Volts.
The Electronics part of the project is relatively easy, but not particularly cheap,
( probably around ~$30.oo USD )
dhruvpatel00764
Joined Apr 28, 2024
20
ok so if i will use simple gear motor. but can circuit sustain current that you have provided in diagram?
LowQCab
Joined Nov 6, 2012
5,102
I have not provided any Circuit suggestions yet,
because I needed more information about the equipment that will actually be used in the project.
Selecting a Gear-Motor that would be appropriate for your project could take many hours of research,
and, I don't know which suppliers are available to your location.
A much less powerful Motor, with gear-Reduction added,
will do the work that You are asking for.
( it looks like this is a Butter-Churn project )
Since You are wanting to reduce the physical-size of the Butter-Churn,
much less Power is required from the Motor, compared to the Churn that is in the video.
The RPM of the Churn must be kept very low to prevent splashing-out all of the Milk.
The Gear-Reduction will provide the additional Torque required
for when the mixture starts to get very thick and viscous.
You can't have too much Torque,
but You CAN DEFINITELY have too much RPM,
this is the reason for having the Gear-Reduction on the Motor.
This project is a lot of work, for a device that seems to have very limited increased-value
over the commercially available options.
If You want to go to the trouble to find, and purchase, an appropriate ~1000-RPM Gear-Motor,
I will provide You with a very versatile Automatic-Motor-Reversing, and Speed-Controlling-Circuit.
I will be waiting to see the selection of Gear-Motors that
You find that may be appropriate for this application.
Some will certainly be better suited to the job than others.
MisterBill2
Joined Jan 23, 2018
28,510
Many long years ago I did spend a few days on a farm where they had, and used, a hand cranked butter churn. Quite a bit bigger than the one in the picture. It is not likely that it would be spun even 100 RPM to successfully produce butter. So definitely an ultimate low speed is required. And probably just a series resistor will provide adequate setability.
LowQCab
Joined Nov 6, 2012
5,102
My plan was to have a very-slow Triangle-Wave modulating a Full-Bridge PWM-Motor-Controller,
made with two 8-Amp-Continuous-Rated Gate-Driver ICs.
Zero-Volts from the Triangle-Wave equals Stop, plus or minus equals forward and reverse,
the amplitude of the Triangle-Wave would control the adjustable maximum speed.
This setup would be very versatile, and handle almost any small Gear-Motor with no sweat,
and a very low parts count.
But I think the TS may not realize all of the
mechanical-engineering that goes into making a project like this successful.
MisterBill2
Joined Jan 23, 2018
28,510
Certainly the mechanical portion of an electrical/electronic product is often the challenge, as well as being the point of failure. Fortunately our design teams were able to communicate early enough so that most of the failures were on the pre-cad-design versions of the products. Pencil sketches are the best places to find design faults.
