Circuit for Reverse Polarity Detection and Charger Detection using Opto couplers
Aj01051996
Joined Aug 6, 2026
The above circuit I am using for reverse polarity and charger detection circuit for a Battery Management System. Here, I have represented +56V as my charger output. So, I have used two Optocouplers, Left one for reverse polarity detection and right one for charger detection. I have provided two logic output such that the left one should be High when the circuit is detecting reverse polarity connection. The right side logic output is for the charger detection such that if the charger is connected, which I have represented +56V, the logic output is Low and if the charger is not detected Logic is high. Is this circuit correct?
AnalogKid
Joined Aug 1, 2013
12,298
Small, low-res image is difficult to read.
Where does the 5 V come from, and does it share a common GND with the 56 V source?
Please add a unique reference designator to each component. without them, the circuit is very difficult to discuss
ak
28,602
Please avoid showing dotted conductors unless that is used to indicate the active part of some circuit. The difference between circuit and "just lines" is clear to most of us.
Please describe the operation of the circuit as to what happens when:
A: ( no charger is connected),
B: (Reveresd polarity is applied),
C: (the charger polarity applied is correct.)
THAT will assure that I understand and can provide a correct evaluation. Presently I do not see how those different conditions will provide signals.
ericgibbs
Joined Jan 29, 2010
21,649
hi Aj,
This is what LTSpice simulation shows for your circuit.
Check the layout for accuracy.
E
Edited to show more clearly polarity change.
What is the input voltage (Vin) of this circuit?
28,602
Certainly the circuit functions, but all it provides is data outputs.
Enable input /disable input actual functions are missing.
For actual use, we need to ENABLE a system whe the inputs are correct. THAT portion is missing.
panic mode
Joined Oct 10, 2011
5,469
no it does not function...
why would anyone think that this can work as reverse polarity detector? if the 56V is reversed, the optocouplers will blow...
the LEDs in them cannot tolerate such high reverse bias (it is 10 times what it can handle)
you need something like this (observe that D1 and D4 connection is antiparallel with optos LED):
28,602
OK, the circuit shown is not able to provide any USEFUL FUNCTION! !
ACTUAL reverse polarity and over-voltage circuits are quite different in most aspects. The best circuits provide isolation until both the correct voltage and polarity are sensed, AND they are usually able to withstand excess voltages.
OFTEN that protection includes both a series resistor and a voltage clamping arrangement to protect rest of the sensor/protection circuit. THAT can be as simple as a resistor and a shunting zener diode.
ericgibbs
Joined Jan 29, 2010
21,649
Hi B,
You obviously, once again, have not read the TS's original requirement
He is using the Output Logic Signals in determine the 56V charge voltage state BEFORE switching the power to the BMS
E
28,602
OK, I suppose. The over-voltage protection packages that I have seen tended to include the portions that prevent excess voltage or reversed polarities from entry. The circuit shown could provide notification, but as sown it provides no mechansm for actual protection, but only a logic level state change.
My apology for being a bit critical. OPtical isolation would probably be appropriate, but it is not likely that the setpoint would be repeatable thru a production run.
lichurbagan
Joined Jul 4, 2025
139
As ericgibbs pointed out, using this as a separate sensing stage for the BMS is reasonable. One additional thing I’d check is whether the battery can feed voltage back onto the charger-sensing terminals. If it can, the “charger detected” output could remain asserted after unplugging the charger. That depends on where the sensing circuit sits relative to the charge-control MOSFETs and any reverse-current blocking.
Panic mode’s point about protecting the optocoupler LEDs also matters. A series resistor alone does not guarantee that an LED stays within its reverse-voltage rating. An appropriately rated diode connected antiparallel across each LED provides a clamp, with the series resistor limiting current in either polarity. Renesas explains why exceeding an optocoupler LED’s reverse rating can cause permanent damage or degradation.
I’d also check resistor dissipation at the maximum input voltage. As an illustration, 5 mA from 56 V through an LED dropping 1.2 V requires approximately 11 kΩ, dissipating about 0.27 W in the resistor. That already exceeds a ¼ W rating before allowing for temperature or voltage margin.
For reliable logic levels, choose LED current and output loading using the optocoupler’s minimum CTR and saturation specifications over the operating temperature range. Vishay’s CTR application note covers those dependencies. The LED turning on is not, by itself, a precise charger-voltage threshold.
Could you show the battery, charge-control MOSFETs and source of the 5 V logic supply on the same schematic? That would help establish the outputs for charger absent, correct polarity and reversed polarity—including during startup.
