- Joined Jan 23, 2018
- 28,508
See Also Post #38, BECAUSE L.Q.C. is totally correct.
At 80 years old I love to see a design that 'works' when the task get tough.I hate "E-Notation" too !!!
I'm not really "Anti-Micro", I'm just not into learning new languages at ~67-years old,
and then keeping up with the latest toys and continual changes.
But, of course, some people obviously have a propensity for learning new languages, more power to them.
Jerry-Hat-Trick also made another observation,
about the quick Code learners not being able to grasp the Hardware aspects.
I've just been a very-part-time Electronics-Hobbyist for ~60-years,
completely self-taught, with zero formal-training,
and I can do better than these young Code-brainiacs ???
I'm of the opinion that anyone should have a good grasp of the hardware FIRST,
as in, basic Analog-Control Circuitry, Op-Amps, FETs, etc..
Life is strange, I guess that's a good thing.
First, I would look at using higher DCV , you may want to look at the LMD18200, or DRV8833 etc boards similar to the L298. it is rated for 3A.I created first basic circuit of my life and it take 3 hours to get it working
how can we make it to take higher current? or can we use npn transistors? etc.
just curious if we can use this driver board below:
https://www.electronicscomp.com/l29...n41Q4TCa2a5KtitFlUu-jf_rjrUEuqGkaAnLLEALw_wcB
thank you for reply. First i used 9v battery because that was only available in tinkercad. in this project can we use 12v 3a smps?The first step towards higher-Current is to get rid of the wimpy 9V-Battery.
You must start with a Power-Supply that can deliver anywhere from ~20% to ~200% more Current
than will ever be demanded by the Load.
And, since your Load is controlled by a Relay, the Relay must be rated for the Locked-Rotor-Amps that
the Motor will draw every time it starts or reverses direction, otherwise
the contacts inside the Relay will be destroyed very quickly.
A Relay is not a Semiconductor, it is a Mechanical-Device that wears-out after X-number of cycles.
Semiconductors normally never "wear-out",
but your specific design choices can cause them to overheat and fail.
HEAT is always the enemy of Semiconductors.
Discrete Transistors can certainly be used, but they tend to not have many of the built-in features
that are built-in to readily available integrated "Controllers",
such as the MOSFET Gate-Drivers that I chose to create a PWM Full-Bridge-Motor-Controller.
The features that they bring to the table are ( at least ) ...............
1)
"Logic-Level"-Inputs, with extremely simple drive requirements,
( 2.5-Volts, with built-in hysteresis ), ( built-in static protection ).
2)
Blazingly fast "Rail-to-Rail" switching with no worries about "shoot-though" blowing things up.
3)
Rated for ~30-Amps Peak-Current, and ~8-Amps Continuous-Current,
( extreme overkill is always good to have ).
4)
Built-in "Under-Voltage-Lock-Out", ( UVLO ), if the Power-Supply drops below ~9-Volts,
( because of possible Motor-overload, or a possible inadvertent short-circuit in the wiring )
This adds an extra layer of protection against accidental smoking of parts.
5)
Two TO-220-5 style Transistor-Packages replace ~8 to ~16 individual Components.
( I would use these just for the construction convenience, if for no other reason )
6)
Greatly facilitates using high-Frequency PWM Motor-Speed, and Reversing-Control,
with a simple to understand and implement format.
And all of these reasons are why I would recommend against using discreet Transistors,
( not to mention the reduction in the number of complex Math-Calculations required ).
Yeah-but, yeah-but, yeah-but, they cost ~$10.oo each !!!!, and I'll need 2 of them !!!
Well it all depends on whether You want to blow-stuff-up in an interesting learning experience,
or put together a very competent device
that has the potential to be better than You can buy at any price.
( I've blown-up a lot of stuff, it can be really expensive, or even embarrassing sometimes )
DRV8833 available here. we can use this module after mosfet right?First, I would look at using higher DCV , you may want to look at the LMD18200, or DRV8833 etc boards similar to the L298. it is rated for 3A.
.thank you for reply. First i used 9v battery because that was only available in tinkercad. in this project can we use 12v 3a smps?
second, if have IRFZ44N which is easily available here how can i connect mosfest instead of relay in this circuit can you please show me?
All though a little off topic, I would come out in the defense of some controllers, having fixed and worked on a few, they are not all the same. !( start rant )
Treadmill-Motor-Controllers are my favorite pet-peeve,
yeah, they "work", kinda-sorta, but they're just junk designed to a price-point.
( end of rant )
ok. can you sketch diagram connected to circuit that i provided so i can understand it. thank you..
For a beginner Project, building a Full-Bridge-Motor-Controller with 4 discrete MOSFETs
will probably be disastrous without using a dedicated Driver-Chip designed specifically for the job.
But, for providing Reversing, and Speed-Controlling abilities,
a Full-Bridge-Controller is practically the only choice there is.
These reasons are exactly why I designed the Circuit that I provided the way that I did.
It's simplicity is very valuable, even though it does cost more, initially, to purchase the parts.
I would never suggest that a new guy try to build a Full-Bridge using Discrete-Components,
it's just entirely too likely to turn into smoke, and be an expensive disappointment.
yes definitely, i will update more as circuit does get finalized.What will be interesting is to see what other portions of the project get built. There is the framework to support the motor and container, the shaft arrangement, some sort of rotary agitator, as well as an enclosure for the control circuit and the power supply. Quite a few details before it will be ready to try out.
.ok. can you sketch diagram connected to circuit that i provided so i can understand it. thank you.
The DRV8833 is a H-bridge motor driver, similar to the L278 with PWM input signal.DRV8833 available here. we can use this module after mosfet right?
