PNP and NPN recommendation for mosfet driver
MrsssSu
Joined Sep 28, 2021
267
Don't do that - current will flow through the base-collector diode of Q1, and you will need a new Q1.
Hi, yes you are right. Q1 is the hottest. So, what should I do to feed the gate of mosfet with 16V square wave if V1 is not allowed at 16V because the voltage fed into gate of mosfet is determined by the magnitude of V1? Thank you :)
Ian0
Joined Aug 7, 2020
13,207
You can't drive 16V into the MOSFET unless your power supply (V2) is >16V
Why do you want to drive 16V into the MOSFET? It is unlikely to work any better than if you use 12V.
MrsssSu
Joined Sep 28, 2021
267
Yes, I know. I am just curious, if V2 is 20V and V1 is 16V square wave, the transistors should be working fine right? So, are you saying that V2 must always be greater than V1 for the circuit to work effectively (transistor not hot) ? Thank you, sir
Ian0
Joined Aug 7, 2020
13,207
Yes. Absolutely.
Usually, whatever voltage supplies the circuitry that generates V1 also supplies V2.
Much more common is V1=5V and V2 = 12V or higher. In that case you need to amplify the voltage, for which I would recommend a gate driver IC.
MrsssSu
Joined Sep 28, 2021
267
Yes. Absolutely.
Hi, if V2 is 20V and V1 is 16V square wave, the transistors should be working fine right? I am planning to test it out:)
MrsssSu
Joined Sep 28, 2021
267
Yes.
Careful, though. Most MOSFETs don't like more than 20V on the gate.
HI, I have tested it. The problem is the transistors buzz and suddenly pop and get spoiled when I use V2 is 20V and V1 is 16V square wave. Hmm, I think I will stick with V2 (12V) and V1 (12V) . I think is because I applied a too high base voltage for the transistors, thats why it buzz and pop:). May I know what are the most common mosfet driver available in the market?
Ian0
Joined Aug 7, 2020
13,207
There are hundreds to choose from. I like MCP1401 and MCP1402. Search for "Low Side driver", there are inverting types, non-inverting types, types with additional logic functions etc.
38,631
if I set V1 at 16V square wave with a 12V (V2), transistor (Q1,Q2) get hot.
That circuit is not designed for an input voltage greater than V2.
The transistors become incorrectly biased and draw a large current.
Why do you want an input voltage greater than V2?
That serves no useful purpose.
MrsssSu
Joined Sep 28, 2021
267
Hi sir, I attached my schematic below. Am i connecting it properly? In this case, I am using V2 lower than V1 because when I tested V2 greater than V1, the transistors becomes hot. :)Inked271828047_1221179888414519_6140697363846638897_n_LI.jpg
DC_Kid
Joined Feb 25, 2008
1,242
What's the goal of the ckt? What's the source (device, or output stage type) for PWM?
Why use bi-polar as driver, just stick a nFet in front of the power nFet. Makes the whole ckt just three parts.
The other Q I have is, does the power fet on/off need to follow PWM on/off times closely, or is some delay ok? There will always be delay, question is, how much is too much, or perhaps it doesn't matter?
DC_Kid
Joined Feb 25, 2008
1,242
Something like this? Fast, crisp, four discrete parts, not much gate current. An interesting thing to look at, Right-clik a Voltage waveform in the simulation window, then View --> FFT. If FFT is of concern, that's a place to look.
DC_Kid
Joined Feb 25, 2008
1,242
Also notice the actual power side PWM changes just a smidge. I changed Vin from 10 to 11.8 so this issue can be more easily seen in the sim window. Signal "on" time is about 1/4us longer.
