I currently have an Energizer CHFC2. It's the only one I have that will charge just one battery without another in the adjacent slot(which comes in handy when you have devices that take an odd number of batteries)
It apparently is supposed to be able to "reject" batteries that will no longer accept a charge. However, I have had several times where the bar graph will go up to "full" in the normal amount of time and stop there, and I'm none the wiser till I try to USE said batteries only to find that they have no charge. They do, if I remove them right away, but not if I leave them sit as "always ready" spares. And no, I don't leave batteries on charge for weeks / months, I remove them at least a few days after. But for some of my devices (like game controllers) I do want to be able to grab batteries I know are ready.
What is perplexing is how the charger fails to detect that the battery is self-discharging while still connected and throw a "bad battery" indicator, when it already has to detect the voltage to be a "smart" charger that stops so as not to fry the battery. (Not dangerous for nickel based batteries, just a major annoyance for the end user, especially if the maximum time doesn't allow for overnight charging)
Even better, it has a separate indicator for "bad battery" that has actually come on before, so I know it's not just a sticker placed there to make it look "smarter" than it actually is. Not sure if the charger has just gone faulty, but it's not as though it's consistently failing to charge any batteries.
I don't need C or D charging ability anymore - I just don't have anything left that takes those, and I have those plastic spacer tubes to fit AAs if needed for restoring / testing an old device. But I do want the ability to charge single cells, not just pairs, and it should have the ability to at least say "bad battery" if it's bad.
Anyone have a good experience with something that's either still made, or its longevity / serviceability is such that I'd still be able to find a working one?
