MisterBill2
- Joined Jan 23, 2018
- 28,596
The LM337 regulator is not wired correctly for it being an adjustable voltage regulator device. The connections are what would be used for a positive fixed voltage regulator device. THAT is the main problem with the circuit that is shown attached.Sir,
please find the attached circuit, I connected this in bread board. The 120 ohm of 1Watt was fired two times. I cant find the reason for its breakdown. got frustrated after building this circuit.
The circuit is not at all correct for the LM337 device .
