negative voltage rails
Homebrew1964
Joined Nov 22, 2024
289
I have built the circuit, the sinewave input from my function generator goes directly into pin 3 of IC2 it is 0.5V above and below ground (1V pk to pk total), my output is only showing the top half of the waveform as expected and i believe i have to supply IC2 with split supply, how do i do that? where do i connect pin 4 of IC2 to please?
sghioto
Joined Dec 31, 2017
8,765
Don't need a split supply if using capacitors on the input and output on version A. Max output appx 7Vp-p at 9 volt supply.
Version B produces a "virtual ground" for the signal input and output eliminating the capacitors on IC2. Output appx 7Vp-p at 9 volt supply
dl324
Joined Mar 30, 2015
18,524
how do i do that?
Use 2 9V batteries. Connect them in series and define the connection between them to be GND. Connect GND from the signal generator to the node you've defined as GND.
I suggest 2 9V batteries because LM741 is severely limited with supplies below that. The input and output ranges are only guaranteed to be withing 3V of the rails.
28,612
Certainly to get an actual negetive voltage as part of a waveform, you must have an actual negative supply voltage to that stage. There are work-around schemes to provide an equivalent output, mostly involving capacitor coupling.
Homebrew1964
Joined Nov 22, 2024
289
I'm using a bench power supply set to 9V
Homebrew1964
Joined Nov 22, 2024
289
Circuit B works beautifully. i expected a gain of 1 though since R3/R4 = 1 ?
WBahn
Joined Mar 31, 2012
33,353
While the output is TYPICALLY 7 Vpp on a 9 V supply, if it only turns out to be 3 Vpp, there's no room to complain because it is still operating within spec.
WBahn
Joined Mar 31, 2012
33,353
Why do you expect that?
You need to spend the time and effort to understand how the basic op-amp circuits behave, which means being able to analyze their expected behavior and not just throw equations around without knowing whether or not they apply to the given circuit.
28,612
Consider that SOME opamps are intended for single supply operation. That is , the LM324 type, at least. Of course, that means no negative voltages in the application. So there isalways a compromise involved.
35,309
Whether a supply rail is positive or negative is irrelevant. The polarity is relative to a reference node.
The solution is to create a reference node that is at the midpoint of the supply voltage. We call this node "COMMON" or PSEUDO GROUND or VIRTUAL GROUND.
We connect all 0-volt references to this COMMON node.
dl324
Joined Mar 30, 2015
18,524
It works for a 1V peak to peak input signal, but the guaranteed input/output voltage swing is only guaranteed to be 3V peak to peak with a +/-4.5V supply. That's why I suggested using 2 9V batteries.
For heavily loaded outputs, it's not guaranteed to work.
LM741 was designed in an era where opamps usually operated from +/-15V supplies.
This is how the gain formulas were derived (from Signetics Analog Applications Manual) using the zero differential input theorem:
dl324
Joined Mar 30, 2015
18,524
That would depend on the application.
I have one LM741 in my parts box and those were the results I got.
Most parts will be typical but, as I said, unless you're prepared to cherry pick parts, you should design for worst case specifications.
WBahn
Joined Mar 31, 2012
33,353
That's true with a 1K load but appx 6Vp-p at 10K as measured in testing.
The 3 V from the rail comes from the spec with a 10 kΩ load. With a 2 kΩ load, it's only guaranteed to get within 5 V of the rail, meaning that it might now work at all.
Also, note that this is with ±15 V rails. With ±4.5 V rails the swing might be different, but probably not by a lot.
You will likely get upwards of 7 Vpp swing, as that is the typical case. But relying on the part you happen to have being typical is not sound practice.
