MOSFET Positive side switching circuit
sab201
Joined Nov 18, 2023
322
I can't understand how you are getting 2 different currents from a constant current converter.
(without changing the settings of the converter)
The output of the buck converter goes to the load through the MOSFET switching module. On the high side there is switching taking place. I connect a resistor in parallel to the switch. When constant current is set, current flows through the MOSFET when PWM is ON. When PWM is OFF, the switch opens and current flows through the resistor. Of course there is power wasted at the resistor when doing this but this is the only simple way to get that waveform.
sab201
Joined Nov 18, 2023
322
Good Day I know it's been a while. I wanted to try out the below switching circuit for a supply voltage of 60 Volts DC, instead of 12 Volts DC.
I replaced the STD46P4LLF6 MOSFET with a SL50P06D MOSFET that is rated for 60 Volts and the 2N3904 with a BC 639 with a higher voltage rating as shown below.
When I tried out the circuit, I give the PWM voltage there is no switching taking place.
What am I doing wrong here. Could someone please help. Thanks.
sab201
Joined Nov 18, 2023
322
Probably damaged the mosfet with 60 volts across the gate. Need to add R4 to reduce the gate voltage to appx 10 volts with a 60 volt supply which is also the absolute max voltage of the SL50P06. Recommend a higher voltage rated mosfet.
Thanks.
I will try it out. Hope the mosfet is not damaged. I will check it. The max voltage I tested it was 50 Volts not above that. I checked continuity at the MOSFET terminals, they weren't shorted. I will install the resistor as per the circuit and post the findings.
ericgibbs
Joined Jan 29, 2010
21,645
hi sab,
Q1 V Base to Emitter voltage should not exceed +0.7V.
Where are you measuring?
Note 'sgh' post ref VGate/Source
E
38,946
My LTspice sim indicated rather slow switching speed for the MOSFTET.
For fast switching speed to minimize MOSFET dissipation with PWM, I recommend changing (EDIT) R1 R2 to 1kΩ and R4 to 5.1kΩ(1W).
sab201
Joined Nov 18, 2023
322
My mistake.
I meant change R2 to 1kΩ.
As sghioto pointed out possibly the MOSFET got damaged. I will try out the resistances as specified.
For now the Vbe is 0 Volts and voltage is present at the output terminals of the circuit when the supply is connected to the input terminals regardless of PWM input. But when load is connected current does not flow.
I am thinking of ordering higher voltage rated MOSFET.
These are the P Channel Power MOSFETs available. Could you please suggest which of the below MOSFETs have a higher switching speed and best suited...
1. RD3N01BATTL1-ROHM-Power MOSFET, P Channel, 80 V, 10 A
2. SQD50P08-25L_GE3-Power MOSFET, P Channel, 80 V, 50 A, 0.02 ohm, TO-252AA,
3. IRF9520SPBF-Power MOSFET, P Channel, 100 V, 6.8 A, 0.6 ohm, TO-263AB
Thanks.
vandveuser16776
Joined Feb 21, 2026
232
There is almost no possibility that the MOSFET survived -60v Vgs as sghioto suggested.
Using a simple resistor divider won't work if you're switching above 1kHz the MOSFET’s gate capacitance will turn your square wave into a ramp. This causes the FET to linger in the linear region, leading to overheating and if pushed to its max current, will certainly die. To drive a P-channel MOSFET at high speed without messing up your duty cycle, you need to use a totem-pole topology (I post below) or if you want to be really pro, you need a gate driver chip. The part numbers I used were just because they were close to your design, but not necessarily have to be. Just the resistors matter and the 11v Zener diode. I made a Spice and seems to be working? The output is crisp square at 50kHz and the Vgs is -11v which is standard
sghioto
Joined Dec 31, 2017
8,763
The above post wouldn't apply if the PWM signal is at .1hz, 5 seconds ON and 5 seconds OFF.
Unless I'm mistaken about that.
sab201
Joined Nov 18, 2023
322
May be I am not able to read this circuit properly...
Where is the input +60 Volts supply in this circuit....
