Any blocking oscillator with a power mosfet ?
Externet
Joined Nov 29, 2005
2,681
Hi.
To convert DC into 120V / 60Hz pulsing AC and then by LC circuitry, make it near sinusoidal for a couple of hundred watts to power a blower fan motor ?
(Instead of using a typical inverter) How would you make one ? For 12, 24, 36, 48 VDC input to 120VAC output ?
Pyrex
Joined Feb 16, 2022
577
It's not a best idea to convert a rectangular voltage into a sine wave using an LC filter. If the load current changes rapidly, the LC filter gives strong voltage spikes.
You can also use a ferroresonant transformer; I've seen a 10kW industrial UPS made that way. The input was 3x400V AC, the battery was 120V, the output was single phase 230V. However, this transformer is big, heavy, and noisy
schmitt trigger
Joined Jul 12, 2010
2,288
Blocking oscillators are very simple but also very inefficient. For the simple reason that to oscillate the transformer has to be driven hard into saturation.
Not only does that increase the core losses significantly, but core saturation means that the core material loses most of its permeability, meaning high current spikes that the switching transistor must carry, which causes additional losses.
For those reasons, blocking oscillators are used for low power, usually 5 watts at most.
B-JoJo-S
Joined Jan 3, 2026
605
A Universal motor can run on AC or DC. As long as you got the voltage right.
"Couple hundred watts" isn't very small. How big is the motor you want to run?
The devil is in the details. Help us help you.
200W (assumed) divided by 120VAC = 1 2/3 amps.
B-JoJo-S
Joined Jan 3, 2026
605
1 horsepower is equal to 745.7 watts. 200 watts is equal to 0.268 horsepower. So you're talking about roughly a quarter horsepower motor. It should be easy to find a DC motor that runs on the voltage you want to start with - without having to spend a lot of money making a not so easy build to run your motor.
why not use fan made for your desired DC voltage (you mention 12, 24, 36, 48 VDC
PM said it first. Makes sense to me too.
28,584
A simple inverter with adequate capability will be te best way to drive an AC induction motor. The second choice is a switching type voltage multiplier scheme. I have seen those circuits but I can't supply any help with them.
The big concern is to not have the frequency too farfrom the motor design frequency. Driving a motor above its intended frequency will run it faster, driving it much below the rated frequency will result in running hotter and at a lower speed.
Pyrex
Joined Feb 16, 2022
577
Baxandall inverter (resonant Royer).
This type of inverter produces sinusoidal voltage. They were widely used to power CFC lamps in monitors and TV's, just their frequency was much higher, around 20-30kHz.
It would be possible to recalculate such an inverter for a lower frequency.
Royer oscillator - Wikipedia
Danko
Joined Nov 22, 2017
2,256
Simple use UPS.
28,584
Is the concern that "A typical inverter" is not so efficient?? OR is this thread intended to explore alternative schemes?
As for suggested a "universal motor" type, not very economical! A quarter horsepower universal motor would not be cheap at all, nor a good choice to power "a blower", because those brushes do wear out and need to be replaced. An average induction motor, like used for 120 volt fans, will last for many years if the bearings are adequately lubricated. Driving a motor from all of those different voltages is by no means a simple task, if efficiency or cost considerations are involved .
Using capacitors to resonate the motor windings at the driving frequency would remove the sine-wave requirement , but not the AC requirement.
The reason that we do not see fans or blowers with such motors is that the scheme to do that is neither simple nor cheap.
The way to do it is to use a simple low voltage motor and a switcher type universal voltage input power supply.
du00000001
Joined Nov 10, 2020
201
For a blower motor, the most simple inverter should do: idle - positive - idle - negative. A filter should not be required - I'd expect the motor to have a sufficiently high inductance to create something like a sawtooth current form the voltage steps input.
Pyrex
Joined Feb 16, 2022
577
I've read reviews that water pump motors work poorly if the power supply voltage is square-shaped. The motor hums loudly and gets very hot.
schmitt trigger
Joined Jul 12, 2010
2,288
The applied volt-seconds of a square wave is 11% larger than a sine wave of the same amplitude. You have to reduce the amplitude by the same amount ti avoid magnetic saturation.
