I need to design a colpitt oscillator to create a perfect sinewave frequency upto 1Mhz using 741 opamp
Status
Not open for further replies.
ericgibbs
Joined Jan 29, 2010
21,433
Hi HaNo,
Welcome to AAC.
Do you have circuit to post that you consider would work with a 741?
The 741 specification is very limited.
E
WBahn
Joined Mar 31, 2012
32,784
Except as a mathematical equation on a sheet of paper, there's no such thing as a "pure" sinewave. Any such specification is meaningless. What is the criteria that your sine wave has to meet in order to be considered pure enough (i.e., acceptable)?
Since you opamp is going to have to have some gain in order to compensate for the losses in the frequency-selective network, you will be limited the gain-bandwidth product divided by the gain (as a rough guide). The further you are below that, the better your circuit will work (i.e., the purer your sinewave will be), again, roughly.
A 741 is generally considered to have a gain-bandwidth product of somewhere around 1 MHz, so you will probably be doing good to get a decent Colpitts oscillator running at much over 200 kHz to maybe 300 kKz.
HaNoWaY
Joined May 3, 2026
26
Thanks for your time
I request you to help me out for a circuit.
I told the exact topic I was given for the project.
Searching the internet I have not got any reliable source to work .
I request anyone can help me with a circuit.
WBahn
Joined Mar 31, 2012
32,784
It is YOUR homework assignment. You need to show YOUR best attempt to solve it. So far, you haven't even shown a start, which indicates you want someone to spoon feed a solution to you. That's not how it works here.
LvW
Joined Jun 13, 2013
2,023
You have mentioned a "colpitt oscillator to create a perfect sinewave frequency up to 1Mhz using 741 opamp"
Besides the fact that no "perfect" sinewave can be produced - what means "up to 1MHz" ?
Do you need a tunable oscillator? Or is a fixed frequency (max. 1 MHz) required?
HaNoWaY
Joined May 3, 2026
26
I just need to display it on the oscilloscope I think it's a fixed one.
U are right perfect not be produced.
HaNoWaY
Joined May 3, 2026
26
No that's not right I have tried many circuit but not got the desired.
The output is coming just a straight line.
These are the following circuit along with output I have tried.
LvW
Joined Jun 13, 2013
2,023
Did you realize that the one and only problem is the requirement: LM741 at 1 MHz?
(When I am not wrong, you oscilloscope shows a fundamental frequency of app. 5 kHz only, right?)
The problem with 741 types is not only the small-signal bandwidth (app 1 MHz) but also the limited slew rate (large-signal rise time).
Such slew rate induced distortions can be observed as "straight lines".
HaNoWaY
Joined May 3, 2026
26
I needed to design a colpitt oscillator not wien. Guide me the main problem I am facing is the spefied opan 741 has to be used.
If 1Mhz is not what is max frequency I can obtain
HaNoWaY
Joined May 3, 2026
26
Yes I realised that to obtain 1Mhz in 741 is not possible in colpitt circuit can u guide the amount of frequency I can obtain in a colpitt using 741.
WBahn
Joined Mar 31, 2012
32,784
I already addressed that.
But that's really neither here nor there. Your assignment specifies a Colpitts oscillator, so you aren't free to pick some other oscillator topology, correct?
Your assignment apparently also specifies 1 MHz, so are you free to pick some other frequency?
We don't know -- we don't have your assignment or know what your instructor has told you about the restrictions and expectations.
Status
