Class D amp, mosfet driver circuit issues
deelakademel
Joined Mar 10, 2026
15
i'm trying to build a discrete class D amp, i've implemented dead time and added a gate driver, but my outputs a little distorted. Could someone point out where i can improve my design. This is the first time i'm working with these circuits so please excuse any dumb mistakes i've made.
Samantha Groves
Joined Nov 25, 2023
186
I don't know the different classes of amplifiers but if you tell me what you want I can help you with that.DC gain(open loop,close loop adjustment),AC gain(open loop,close loop adjustment,bandwidth)
deelakademel
Joined Mar 10, 2026
15
The output from the h bridge should ideally be smoother i guess. I have to pass this through a low pass filter to get the audio signal.
ronsimpson
Joined Oct 7, 2019
4,888
That looks good.
The output looks better than most people's try.
M1 Gate is being driven incorrectly. Try using a "Half bridge gate driver". Like the LTC444. See below. This IC is built for this job.
If M1 was a P-MOSFET, and the signal was inverted, then it probably will work.
Orson_Cart
Joined Jan 1, 2020
110
As said just earlier - if OP would post complete clear schematics ( some of us do not want to download .asc files ) then the matter would be quickly cleared up - as usual ( always ) it is the gate drive.
28,583
AWild guess is that not all of the transistors switch at the same speed. THAT would be the cause of the over-shooting distortion. AND, any resistance in the power feed to the gate driver would slow the drive voltage rise and fall times.
There are definite reasons as to why very low distortion amplifiers are expensive: They AREmore complex, often quite a bit more complex.
ronsimpson
Joined Oct 7, 2019
4,888
Schematic.
Waveforms
See attached SPICE file. There are some problems with it but that is all the time I have right now.
The first one of these I built was in about 1980. It worked but the switching frequency was too low for good audio. Back then we fought to switch above 20khz. Now we are switching at 1mhz.
RonS.
Ian0
Joined Aug 7, 2020
13,315
Schematic.
Waveforms
RonS.
Is M3 upside down?
