Class AB Amplifier
38,932
That is a simple design that will not give anywhere near the theoretical 7W output with reasonable distortion.
Below is the sim of a slightly more complex Marleys circuit, which uses a differential input stage with negative AC and DC feedback from the output to stabilize the output bias point at 1/2 the supply voltage, and reduce the distortion.
D1 and C6 bootstrap the output bias voltage to increase the positive output voltage before clipping occurs.
Its 4W maximum output with about 0.2% harmonic distortion, is likely about as good as you can do with a reasonably simple circuit and a single 20V supply.
To see the distortion value, look at the Spice Error Log after doing the simulation.
35,284
Power output depends on the supply voltage and loudspeaker impedance. Do the math.
20 VDC supply will give about 6 VRMS output.
P = V x V / R = 6V x 6V / 8Ω = 4.5 W
4 W output is very loud for comfortable listening to music in an averaged sized room.
28,527
The REALLY BAD NEWS is that there are a whole lot of folks who choose MUCH GREATER room sound levels. (96 Decibels on a B&K sound level meter.) Certainly, 80dB is quite uncomfortably loud by my evaluation. JUST AS CERTAINLY , though, I have no intention of forcing my choices on others. I have repaired a 700 watt audio amp for a person who was quite willing to pay for the repair. My checkout to verify it was fixed did not involve full volume listening.
hobby2026
Joined Jun 13, 2026
9
Hi
How did you get the 6 volts MrChips?
38,932
20V is a convenient voltage since it is near what laptop supplies output.
But if you want more power, I have versions of the Marleys circuit that operate with a higher supply voltage.
hobby2026
Joined Jun 13, 2026
9
It's 4W maximum output with about 0.2% harmonic distortion, is likely about as good as you can do with a reasonably simple circuit and a single 20V supply.
Hi Crutschow
Can you tell me what kind of feedback is provided by C6 and D1 and how these values were arrived at?
What do R11 and C3 do and how these values were arrived at?
What do C2, R4 and R5 do and how these values were arrived at?
I want to understand how this amplifier works before I build it.
Thanks.
38,932
They do not provide "feedback" as such.
They generate a bootstrap voltage by charging C6 to Vcc through D1 when the output signal is at a low peak.
The C6 voltage then rises above Vcc to provide base drive to Q5, even when the peak output gets close to Vcc.
The value of C6 was just selected for its voltage to not drop significantly during a low frequency output as shown by the simulation results.
They provide collector-base (Miller) negative feedback rolloff at high frequencies for a smooth high frequency rolloff with no peaking.
The values were determined by looking at the AC Bode frequency plot and adjusting their values for the desired response.
They provide AC and DC negative feedback from the output.
The DC feedback gain of 1 keeps the output bias voltage at 1/2 the supply voltage as determined by the differential input DC voltage generated by the voltage divider R1 / R8.
The AC feedback reduces the distortion and determines the circuit gain.
R5 was selected to not have a significant voltage drop due to Q2's base bias current.
R4 was selected for an input-output AC circuit gain from the negative feedback as determined by the R5/R4 ratio to give about 8V peak output for a 1V peak input voltage.
C2 blocks DC so the DC feedback gain is one, and is make large enough to not have a significant impedance compared to the value of R4 at the lowest desired circuit frequency (typically 20Hz).
hobby2026
Joined Jun 13, 2026
9
The do not provide "feedback" as such.
They generate a bootstrap voltage by charging C6 to Vcc when the output signal is low.
They provide collector-base negative feedback rolloff at high frequencies for a smooth high frequency rolloff with no peaking.
The values were determined by looking at the AC Bode plot frequency response and adjusting their values for the desired response.
The DC feedback keeps the output voltage at 1/2 the supply voltage as determined by the differential input voltage generated by voltage divider R1 and R8.
R4 was selected for a input-output circuit gain as determined by the R5/R4 ratio to give about 8V peak output for a 1V peak input voltage.
C2 is make large enough to not have a significant impedance compared to the value of R4 at the lowest desired circuit frequency (typically 20Hz).
Thanks very much!
28,527
To see a quite large selection of audio amplifiers, ranging "from Milliwatts to Kilowatts,", visit the "Schematics For Free" website. Free downloads of circuits and no malware attached.
