MOSFET Positive side switching circuit
sab201
Joined Nov 18, 2023
320
Did you get those voltage readings?
I checked... Gate to ground voltage is the same as the input supply voltage 13 Volts DC without any pwm.
Let me know if any other voltage or current reading needed to be checked.
sab201
Joined Nov 18, 2023
320
Post a clear photo of the circuit so I can see the connections on the mosfet.
Ok I will post. But I remade the circuit, the same problem persits. I dont think the zero PCB board and its soldering connections will be clear. Also soldering an SMD MOSFET seemed to be a challenge. I am not an experienced circuit maker BTW.
I have done continuity tests for short circuit it is all fine.
ericgibbs
Joined Jan 29, 2010
21,567
hi sab,
I have cleaned up your images, also flipped the copper side to show it looking through the PCB, makes it easier to check the tracks.
E
sghioto
Joined Dec 31, 2017
8,750
Yeah that's pretty much impossible.
Label those 2 green connectors on the board. Which one is the power supply and which one is for the load.
Show which pins are negative or ground and which pins are positive.
sab201
Joined Nov 18, 2023
320
You want me to connect the drain to the + of the Load and source to + of the Supply?
That is not how it is in the circuit
sghioto
Joined Dec 31, 2017
8,750
Yes and the schematic is correct but you have the labeled the mosfet incorrectly.
See the symbol below.
Now configure the circuit as shown, pleassssssse. :)
sab201
Joined Nov 18, 2023
320
sghioto,
Yes... That is correct. I made a mistake...
Thanks a lot for correcting it...
I will reconfigure the circuit and post it. It ll take some time....
sab201
Joined Nov 18, 2023
320
Yes that was the mistake. Now its working fine. Thanks for helping out.
I have connected a resistor in parallel with the MOSFET switch terminals. I have set the current to 1.4 Amperes when the switch closes and 0.7 Amperes when the switch opens(current flows through the resistor). Now this is what I get at 0.1 Hz. 5 seconds MOSFET is ON followed by 5 seconds OFF PWM signal.
Still there seems to be little bit fluctuation but it is much lesser than when I used the readymade module.
Here is a link to the video:
https://drive.google.com/file/d/15Lqihrc3TKwFlmBIarrteK4JjqTZO1ad/view?usp=drivesdk
sab201
Joined Nov 18, 2023
320
What is the resistor value used to test with?
Does the supply voltage remain steady during the test?
Its ok sghioto, the current is steady (while swiching) after I increased its value. Now it is 1 Ampere low and 2 Ampere high.
The supply is from a constant current buck converter that I mentioned in the beginning of the thread.
Its a 10 Ohm 100 Watts variable resistor. The load is an electromagnet. I have connected a 50 Watt halogen lamp in series. I suppose the fluctuation happens below 1 Ampere.
For now it works ok.
Thanks.
