Application
The motor datasheet gives no stall current or inductance, so:
- Low-side switch, on/off only, no PWM, Bussman 20A slow blow fuse on motor line.
- Maximum 10 operations per day, always more than 45 minutes between restarts
- 28 VDC from solar-charged batteries, isolated control, charger with TVS protection.
- Gate drive: 4N25 optocoupler, emitter follower, 47 Ω series resistor, 15 kΩ gate pulldown
- Motor: small brushed DC pump, 17 A running current
- Cable to the motor: 2.5 m (5 m round trip), 2.5 mm²
- Flyback diode: MBR560 (D13), installed in the junction box at the motor
- Protection across the MOSFET: 1.5KE36A TVS (clamps about 50 V) and 15V zener across gate.
- Winding resistance: 0.192 Ω, measured (bench supply, 3% series resistor, millivolt reading across motor and resistor)
- Stall current: about 100 to 120 A, estimated from 28 V and the circuit resistance (motor, cable, Rds(on)), less with battery resistance
- Winding inductance: about 0.5 mH, estimated (range 0.2 to 2 mH), not measured
- 3 prototypes, about 50 months of operation in total, switching small pumps at an average of 6 cycles per day per unit
- One failure: drain-source short on an IRF3205 (a 55 V part). No diode failures, no MCU failures, no fuses blown.
- Replace the IRF3205 with an IRFB4110 or STP310N10F7 (100 V, about half the Rds(on))
- Install 1.5KE36A across drain and source as shown. Actually 3205 is not clamped. New MosFet will be.
- Add 15 V zeners at the gate, as shown.
- Recheck the turn-off time with the new gate charge (expected well under 1 ms with 15 kΩ)
- Is the 1.5KE36A across the MOSFET enough, or should I also protect the +28 V input with additional protections against battery and charge-controller transients?
- A shorted MOSFET leaves the pump running permanently. What is the best fail-safe: a fuse, a series relay, or a firmware timeout?
- Is the 4N25 emitter-follower drive too slow for these MOSFETs, or acceptable at this switching rate?
- Is the 100 V rating with about 50 V clamping a sensible margin, or would you go further?
