H-bridge using IR2184 chip.
Status
Not open for further replies.
MrsssSu
Joined Sep 28, 2021
267
Hi all, I want to implement a H-bridge driver circuit. May I know how to make some changes to the circuit above so that it forms a full-H-bridge using transistors. I attached my LT Spice file below :) Thank you for reading.
38,952
You just duplicate the complete circuit for the other two transistors.
For a 0.2ms period signal, C1 has to provide the current the transistor base through R1, so the C1R1 time-constant should be at least 10 times that period or 2ms.
This gives a C1 value of of 2ms / 5k = 400nF.
I would use at least 1µF.
MrsssSu
Joined Sep 28, 2021
267
Hi sir, is this correct? I get a really bad output at R4 :(
ronsimpson
Joined Oct 7, 2019
4,903
Look at Q4. Its input Base or Gate is at near 0V all the time. But it is tied to the input of Q1 who's Base or Gate goes from 0V to 20+15V. (if it has a Gate) or 0 to 20+0.7 for a Base.
Status
