Error simulating a sigma-delta ADC design in LTspice.
Chethan_Raj
Joined Aug 1, 2022
26
Hello there, I've been try to learn how sigma-delta ADC works, I've been through the block diagram mostly and tried simulating one myself by following this video lecture from "The signal path" channel, the wiring is right as it shows in the circuit diagram( from timeframe 34:30 ) and it also follows the other block diagrams i came across, I have tried using the D flip flop as an 1 bit DAC with its 2 values set between +/- 5v, as said in the video, why doesn't this simulation work as intended, am i missing something here with reference voltages?, I have included the simulation file below. Please help me resort this issue, Thank you.
ericgibbs
Joined Jan 29, 2010
21,517
Hi CR,
When using that comp model, I get this error message, which is related to that comp model.
Do you get the same error?
E
BTW: I do have the bordodynov ZZZ folder
