The analysis looks good I guess, (still on post #98), however can we please get back to the starting point of designing a CC amp. as posted in post #93.
Your getting way ahead of yourself when your talking about CC darlington pair.
First of all, the circuit design I did in post #75 pointing to "lesson 3" was just an excersise in biasing transistors for determined currents and voltage references, and at the end be able to turn it into a audio amplifier to drive a 8 ohm spkr.
To design a transistor power amplifier, it is common to use a class AB configuration to achieve power efficiency as well as hi fidelity output.
I have just made another very effective audio amplifier using all 2n3904's with DC coupling, where each transistor stage takes the place of a bias resistor for the stage it drives, exercising learning how to bias transistors and still have a usefull amplifier at the end.
So my designs are not failures per say, but they are not the norm, in power amplifiers used to drive heavy spkr. loads, as you are suggesting about spkrs. in parrallel and such.
That's why I keep saying go back to the very basics of amp design, starting with post #93, I posted pics. of the texts I learned this from so you can read the design steps, then I used those design steps to design a simple CC amp. that worked according to design requirements.
Do not use a spkr. but start out by developing a signal voltage (nondistorted) AC coupled, across a pure resistance, if you use a resistor you can see how the transistor handles a resistive load, then change it for a spkr. load, to see how the circuit responds.
Build or simulate that design with the component values I used, then begin changing values of ,load, VCC, base resisor, emitter resistor, and see how the circuits performance changes.
Once you get a good grounding of understanding the in's and out's of that simple stage, then you can have a better idea how to couple that stage, with Zout of other stages be it AC coupling, or DC coupling.
From there we can take it slowley, adding to it a couple of preamp stages all DC coupling to get a feel for BIASING transistors, and learning how and when to use bypass capacitors, when and how to use miller caps. to eliminate unwanted oscillations, then finally when you have an actual working amplifier, with stability in component changes and temperature, ect..
then you should be ready to design AC coupled stages, then finally in the audio range, and actual class AB power amp, that you could use to drive spkrs. to high DB of voume with no distortion.
But it all starts with the basics. If you have any questions concerning the design steps in post #93 I'll help you with it.
But all these other questions your asking in the newer posts, someone else can help you with, as it is beyond my expertise, as this is only a hobby for me.
ps: I'll look over your last post, and try to answer anything I can, however please consider what I wrote above.
Thanks.
Thanks.
