Common emitter amplifier
electronicsenjoyer089
Joined Feb 24, 2025
182
Hello all
I built a common emitter amplifier with these requirements: VCC=20V, Ic=10mA Av=2
What i did is calculating RC first of all with this formula VC=(VCC-RC•IC) where i chose the vc half of vcc, to have full dynamic so VC= 10V. and i found that RC=1k, now i chose RE in order to have 2 as gain, so RE=500 Ohm
After that i calculated VE as VE=RE•iC , since ic=ie and found that VE=5V.
At this point know that VB= VE+VBE
so now i calculated VB=R2/R1+R2•VCC so 5.7=R2/(R1+R2)•20 , now if we suppose that hfe is 100 and the IR2 current needa to be 10•IB we get that R2= 6.3kohm and R1 by doing the inverse formula we obtain R1=16k
By simulating it looks working fine, but i had a question now RE the way i calculated it isnt the best for stability of the circuit cus transistor changes its parameters also with its temperature, then how can i consider that too? thanks all.
35,245
You cannot have it both ways.
Rc was already restricted to 1 kΩ.
To get a gain of 2 you would have to tweak RE to 420 Ω.
The current gain of the transistor can vary from one transistor to another and with Ic.
The circuit performance will not change with beta.
Joined Feb 24, 2025
182
Yeah i know, but maybe there is another approach to have the same gain with same ic current , but maybe better RE value for higher temperatures? its just my theory tho, i dont know, thats why im asking
38,872
The emitter resistor value has little effect on the temperature sensitivity for a circuit gain of 2.
The value of the collector and emitter resistors are selected for gain, and to get the desired frequency response, since higher values will give a lower maximum frequency response, due to the effects of parasitic circuit capacitances.
Joined Feb 24, 2025
182
Well in case i wanted a higher gain? how i would proceed?
BobTPH
Joined Jun 5, 2013
11,662
To get higher gain, you can bypass Re or part of Re with a capacitor. The DC operation is the same, but the capacitor reduces the Re for AC.
For instance, split the 500 Re into 100 and 400 and bypass the 400 with the appropriate sized capacitor and you get an AC gain of 10 with the same stability as your original calculation.
Joined Feb 24, 2025
182
Oh in this way im adding a parallel resistor ( so RE is lower basically for AC component ) and in this way i get higher gain right ?? thats a smart way, but u need to see relation beetwen RE and the impedance of the cap that changes with frequency no?
BobTPH
Joined Jun 5, 2013
11,662
Yes, C must be calculated to have impedance small compared to R at the lowest frequency you want to amplify.
This is the standard way of controlling the gain of a CE AC amplifier, making it insensitive to transistor beta.
38,872
Please, could you verify/explain this statement?
In contrary - I think the DC-stability of the circuit against temperature changes is proportional to the loop gain LG=-gm*Re .
Okay, but the temperature change effect at a DC gain of two would not be significant over normal temperature changes.
