Common Emitter Design
copypaper
Joined Jun 14, 2025
How should I approach the question with a solution? I don't have much of an idea, I need it urgently. Assume RL resistance is 20k
WBahn
Joined Mar 31, 2012
33,199
The you need to go back into your text (or other material) and get some idea this time around (revisiting concepts that didn't gel the first - or nth - time is part of the learning process, particularly in technical subjects).
The show your best attempt to get as far as you can. If nothing else, determine what you think are limits on min/max component values in order to satisfy the various specifications.
Do that, and then we are in a position to point out things you've done right and wrong, and also things you've overlooked so that you can see how they affect your results thus far.
nologic
Joined Jun 22, 2020
11
you know that the output voltage needs to vary by approximately +-12 to give you the peak to peak voltage swing. You know the attenuation at the corner frequency. So given the knowns you could start by calculating Vcollector at the corner freq, this should allow you to calculate Rc. Thats a starting point
Ian0
Joined Aug 7, 2020
13,279
I wonder what the point of designing it for 10Hz cutoff it it's going to have a high-pass frequency of 20kHz?
WBahn
Joined Mar 31, 2012
33,199
I think that it probably meant to say that the "high frequency cutoff" is 10 20 kHz.
Edit: Fix typo.
WBahn
Joined Mar 31, 2012
33,199
I took it as audible range 10Hz to 20Khz, not that it changes the approach:)
The 10 kHz was a typo on my part.
I'm also assuming that it is supposed to have a first-order band-pass characteristic with corners at 10 Hz and 20 kHz.
But that IS an assumption.
Ideally, the TS should go back to the instructor and ask for clarification. If nothing else, that demonstrates that the student is actually paying attention to the specifications, which in and of itself is actually shockingly rare.
35,183
We know what the writer of the assignment meant. It is simply worded with the opposite of what was intended.
It should have said low pass filter with cutoff frequency at 20 kHz.
Ian0
Joined Aug 7, 2020
13,279
How much confidence can you have in the course if whoever is writing the assignment makes such a basic error?
