Two step pushbutton switches and weird datasheet numbers
Andersons
Joined Sep 28, 2019
32
Hello. I’m looking for two step pushbutton switches (ON)-(ON). I was looking at this datasheet: https://eu.mouser.com/datasheet/2/603/p4-catalog-pdf-1145024.pdf
In the section ”ACTUATORS FOR BASIC SWITCHES” for example rugged seal panel switches doesn’t make sense in reference to the ”P4 PART NUMBER CODE” in the datasheet. For example part nmr. P4-10050-1, what’s that supposed to mean? In the part numbers chart there’s no zeros listed, and switching action is 1-3, there’s no 5.
Andersons
Joined Sep 28, 2019
32
So the P4-10050-1 (red) and P4-10050-2 (black) is a two step pushbutton switch with one pole for each step, with the configuration OFF-(ON)-(ON)? Similar to the description in section ”standard sealed twostep” to the right column, under ”sequence of action” but instead of NC it’s NO, and each step close each circuit momentary? Or am I reading the datasheet wrong?
