Hello everyone,
I am currently working on a 4-bit Two-Step Flash ADC in LTspice for a university project.
The architecture includes:
I would appreciate advice on the following points:
Thank you.
- Sample-and-Hold
- Coarse ADC
- DAC
- Residue amplifier
- Second Sample-and-Hold
- Fine ADC
- D Flip-Flops for synchronization
- CMOS models:
- Which NMOS and PMOS models do you recommend for a CMOS implementation of a Two-Step Flash ADC in LTspice?
- Are there any reliable models or libraries commonly used for ADC design and academic projects?
- Clocking:
- How should the clocks be distributed between the Sample-and-Hold stages, ADC stages, and DFFs?
- Should all blocks use the same clock or multiple clock phases?
- How do you determine the required delay between the coarse conversion stage and the fine conversion stage?
- Glitches:
- What are the most common causes of glitches in a Two-Step Flash ADC?
- Have you encountered synchronization problems between coarse and fine conversion outputs?
- What techniques are typically used to eliminate these glitches?
Thank you.
