ADC two step flash
Raph1902
Joined Jun 11, 2026
3
Hello everyone,
I am currently working on a 4-bit Two-Step Flash ADC in LTspice for a university project.
The architecture includes:
  • Sample-and-Hold
  • Coarse ADC
  • DAC
  • Residue amplifier
  • Second Sample-and-Hold
  • Fine ADC
  • D Flip-Flops for synchronization
The ADC is working, but I am experiencing glitches on some output bits and occasional code transition errors.
I would appreciate advice on the following points:
  1. CMOS models:
    • Which NMOS and PMOS models do you recommend for a CMOS implementation of a Two-Step Flash ADC in LTspice?
    • Are there any reliable models or libraries commonly used for ADC design and academic projects?
  2. Clocking:
    • How should the clocks be distributed between the Sample-and-Hold stages, ADC stages, and DFFs?
    • Should all blocks use the same clock or multiple clock phases?
    • How do you determine the required delay between the coarse conversion stage and the fine conversion stage?
  3. Glitches:
    • What are the most common causes of glitches in a Two-Step Flash ADC?
    • Have you encountered synchronization problems between coarse and fine conversion outputs?
    • What techniques are typically used to eliminate these glitches?
Any recommendations, examples, references, or LTspice projects would be greatly appreciated.
Thank you.
Raph1902
Joined Jun 11, 2026
3
https://drive.google.com/drive/folders/19mbr6joYBY9NFJ6kHN5kXdAXvVb2hHJj?usp=sharing
The project files are quite large, so I uploaded them to Google Drive instead of attaching them directly.
The main file is ADC4bits.asc (ADC4bits), which contains the complete top-level design of the 4-bit Two-Step Flash ADC. The other files are supporting blocks used by the main schematic.
Here is the Google Drive link:
[Paste your Google Drive link here]
Thank you for taking the time to look at the project. Any advice regarding the CMOS models, clocking strategy, synchronization, or the glitches I am observing would be greatly appreciated.
