Popular Switching Power MOSFETS for step up boost converters?
tdengineer
Joined Oct 21, 2025
38
My switching will be around 2-3A and the output voltage will be 150V max, 100khz.
Im looking on digikey and I asked AI but I dont really know which ones are the good ones that are commonly used.
panic mode
Joined Oct 10, 2011
5,244
you would want part that hand handle a but higher voltage (200VDC+), also higher current rating for thermal limit..s. and of course low Total Gate Charge (Qg) and low Input Capacitance (Ciss) to reduce switching losses. one of very common parts is IRF640N but there are many alternatives.
Ian0
Joined Aug 7, 2020
13,276
If you get too small a device, then Rds(on) is high and you get conduction losses.
If you get too large a device, then it does not switch as fast and you get switching losses.
(You can make it switch faster, but that needs a larger gate driver(
Somewhere in the middle is the device that gives the lowest overall losses.
tdengineer
Joined Oct 21, 2025
38
what you think about this one
IRF640N
Ian0
Joined Aug 7, 2020
13,276
0.18Ω Rds(on) gives 1.62W dissipation at 3A. I suspect it's bigger than it needs to be. I bet IRF630 might do the job.
But they are both old devices (introduced in 1979). You could probably get a more modern device with Rds(on) that low with lower gate charge.
ronsimpson
Joined Oct 7, 2019
4,811
Because I don't know the input voltage, I cannot give a good answer.
Known, output3A at 150V.
Not known, input is 75V at 6A. (or slightly higher current)
Not known, duty cycle is 50%.
Not known, the current ramp might be 0 to 12A at 50% of the time.
The input voltage might be 15V at 30A. Who knows.
