Hi, I'm having issues with a IR2110 based MOSFET driver circuit, specifically IRLZ44N, the signal comes in from my signal generator at 5vpp, then goes into pin 12 on the IR2110 and reaches it correctly, pin 11 and 10 to GND, pin 9 to pin 3 on the 7805 5v regulator, pin 3 is vcc so it goes to the 15v rail, pin 2 to gnd, and pin 1 to the gates of both MOSFETS, connected via a 10ohm Resistor, and both mosfets are in parallel so G to G , D to D, S to S, and the Sources are tied to ground, and I've placed a shottky diode on the load output, the load is a resonant coil 0.47mH and 0.5Ohm resistant large loop but when the 5Vpp square wave signal is inputted the mosfets are not switching correctly one side of the load is connected to the drains and the other side o the load is on the 15v rail with the diode across it , any ideas or help would be appreciated, thanks guys this is my first perfboard
