Hi everyone,I am working on an educational electronics project for students. The goal is to design a simple PCB for a 555 PWM DC load controller. The same board may be used with different small 9V or 12V DC loads, such as a DC motor, DC fan, small bulb, mini water pump, LED strip, or a small solenoid.
The circuit uses an NE555 timer to generate a PWM signal. A potentiometer changes the duty cycle, and the 555 output drives an IRLZ44N logic-level N-channel MOSFET as a low-side switch.
Basic operation:
- NE555 generates PWM.
- RV1 controls the duty cycle.
- Pin 3 of the 555 drives the MOSFET gate through a 220 ohm resistor.
- A 10k resistor pulls the MOSFET gate down to ground.
- The load is connected between +V and the MOSFET drain.
- The MOSFET source is connected to ground.
- A flyback diode is placed across the load for inductive loads.
Main components in the schematic:
- U1: NE555 timer
- RV1: 10k potentiometer
- R2: 1k
- C1: 100nF timing capacitor
- D1, D2: diodes for separate charge/discharge paths
- C2: 10nF on the control voltage pin
- Q1: IRLZ44N MOSFET
- R1: 220 ohm gate resistor
- R3: 10k gate pull-down resistor
- D3: flyback diode across the load
- Supply: currently shown as 9V, but the final PCB may use 9V or 12V depending on the load
Planned PCB features:
- 2-pin screw terminal for power input: +V and GND
- 2-pin screw terminal for load output: LOAD+ and LOAD-
- Flyback diode footprint across LOAD+ and LOAD-
- Fuse or polyfuse footprint on the positive supply line
- Test points for +V, GND, PWM output, MOSFET gate, and MOSFET drain/load-
- Optional LED indicator for PWM output or load output
The attached schematic shows one example load connected at the top right. In the PCB version, this load will be replaced by a 2-pin terminal block labeled LOAD+ and LOAD-.
Questions:
1. Does the schematic look correct for driving small 9V/12V DC loads using PWM?
2. Is IRLZ44N a good MOSFET choice for this educational PCB?
3. Should I change the potentiometer value from 10k to 100k, or is 10k acceptable?
4. Is the 220 ohm gate resistor and 10k gate pull-down resistor suitable?
5. Is it acceptable to keep the flyback diode footprint permanently across the load output, while selecting the actual diode rating based on the load?
6. Where should the fuse or polyfuse be placed: before the whole circuit or only before LOAD+?
7. What PCB layout precautions should I follow for the load current path, MOSFET, grounding, and 555 decoupling?
8. Are there any missing components, such as extra decoupling capacitors or protection parts, that I should add before sending this to a PCB designer?
This is for a beginner-friendly educational project, not an industrial product. I would appreciate any feedback before I move to PCB design.
