I have this motor. Should be a 72 volt, shunt DC motor as I understand it. However I have never heard of this type of motor until I received this one and did some googling on it. When googling for a shunt motor driver, I can't seem to find anything. This was taken out of a GEM golf cart originally. But a replacement controller for said vehicle is well into three figures, sometimes $1,000 or more. So I'm trying to find a cheaper option. I don't need it to be super efficient, but I would like it to be fairly powerful as I'm going to build a vehicle from scratch for it. Probably just some kind of little side by side, so even though it's full input rating is 5 KW, I don't think I'll ever be putting it close to that except in acceleration sometimes. Is it possible that I can just current limit the field winding and run that at a good voltage basically creating electromagnet, then simply treat the armature windings as a brushed DC motor? Or will that ruin something? I did something similar with an alternator that I converted and used on a previous go-kart by simply providing 12 volts to the armature winding and then treating it as a brushless DC motor and getting a brushless controller. It had a hard time starting at zero RPM sometimes but as soon as it got going it worked fine. Would that also work for something like this? Or does anyone know of a relatively inexpensive 72v shunt motor controller? Thanks!
EDIT: Also does anybody know what that three wire connector thing is for on the back of it?
