Help finding a way to power/control this motor please!
JohnSan
Joined Sep 15, 2018
141
Well yes. It does use pwm.
But, BLDC motors have three windings, connected star or delta internally.
Hence their controllers have three outputs.
If you can find a controller that can be configured to only drive two of it's outputs, maybe it would work?
I've never seen one.
28,517
And why is that?
I've seen a lot of arm waving saying it won't work, but no technical reason.
How does a brushless controller, such as the one I posted, control the motor speed? Understand that a BLDC motor runs like a synchronous motor, with the speed set by the phase rotation speed (the drive frequency)
Does it not use PWM?
The two types of motors: brushless, versus DC field with a commutator, are about as different as motor types can be. THAT is why a BLDC controller can not possibly control a wound-field brushes and commutator type of motor. THAT has already been explained very well.
Others have already provided very good information, from what I see.
IN ADDITION!! Read the tag that is very clear in the photo!! THIS IS A SHUNT WOUND MOTOR!!
Whatever control scheme is selected must be suitable for a SHUNT WOUND DC motor! Certainly a PWM control for that 58 amp armature circuit, with a separate control for the field, can work very well. AND, since probably a reversing option is also intended, it will be much more cost effective to switch the six amp field current to reverse the motor.
AND, I would wager a fistfull of dollars that the TS in post #1 did not make an ALTERNATOR power a go-kart. It would have been a GENERATOR, which has an armature connection and a field connection, or possibly two field connections.
To spin an alternator there must be an alternating three-phase voltage applied to the field and a DC source to the armature. At least for every brand of automotive alternator I have ever seen.
MaxHeadRoom
Joined Jul 18, 2013
30,878
There are also two methods of controlling the BLDC type motor, one with DC energising two of the three windings at any one time, (BLDC) , and using the identical motor with 3phase supply making it 3ph AC,
The BLDC is considered most efficient for a fixed model of motor.
The BLDC motor typically has 2 to 8 pole count which has to be kown for a given RPM rate.
28,517
Back in post #1 the motor was described and the label was shown. Armature current and field current were listed. That is about as different from a BLDC motor as can be.
What makes a BLDC motor rotate is called "Phase Rotation", the same as common three pahse power, except often square waves instead of sine waves.
It is very UNLIKELY that any BLDC motor controller could drive that SHUNT FIELD DC MOTOR described in post #1!!
28,517
REGARDLESS of the other opinions, the tag ON THE MOTOR shown in post #1 describes a wound field BRUSHED motor.
The controls for a BLDC motor are not at all suitable, nor even adaptable, to that motor shown in post #1
A Brushless DC motor is a multiphase (At least 3 phases) AC motor. That type of motor requires a driver able to provide three outputs , although some BLDC motors require five or more phases.
I had this discussion with one of the salesmen at a company that I worked at many years ago. The issue was resolved when the sales guy received the price quiote for reworking the brushed motor to a three-phase AC motor. That price was a lot more than for a NEW motor.
NO amount of wanting it to be different can change that.
(Sorry for that bad news)
MaxHeadRoom
Joined Jul 18, 2013
30,878
I have this motor. Should be a 72 volt, shunt DC motor as I understand it. However I have never heard of this type of motor until I received this one and did some googling on it. When googling for a shunt motor driver, I can't seem to find anything.
Before BLDC mptors these shunt wound field types were used extensively in industry, lathes. milling machine spindles etc, but one safety precaution was usually made which was to fit field loss protection.
The reason is that if a wound shunt field motor loses field when under operation, The motor can acelerate uncontrollably up to destruction.
MaxHeadRoom
Joined Jul 18, 2013
30,878
Incidentally the reason for BLDC is that only 2 of the 3 windings are energised at any one time, If all three recieve energy, then it is ran as a 3ph version.
28,517
Certainly MAX is correct. BUT 3-phase motors are specificly designed to be "3-phase motors". An actual BLDC motor is designed for that rotating magnetic fields sort of operation, and I suspect that the rotors are quite different from three-phase induction motors. But since I have not investigated the internals of a BLDC motor I will not comment.
28,517
When used as AC motors, they do not rely on induction/slip, therefore run as synchrounous motors using the high magnetic, PM rotor field.
THAT mode is what I would expect!
AND, for those who asked about speed control for BLDC motors, that is indeed how it is done: The speed is set by the phase rotation frequency, just like a synchronous motor. Except that there may be some slip, like an induction motor. I THINK!
My GUESS is that within the broad catagory of BLDC motors there are both synchronous kinds and non-synchronous kinds. I HAVE NOT STUDIED THEM YET!!
28,517
Two points about shunt wound motors. 1/ The do not work on AC. I think the reason for this is the the field winding has a significant inductance so the the phase of the current will be out of phase ith the voltage. The armature has quite low inductance so that the armature current will be about in phase with the voltage. In the case of series motors the armature and field currents must be in phase as they are in series. 2/ Reducing the field current on a shunt motor increases it's speed and reduces the torque.
Les.
A separately powered field (shuntfield)brushed DC motor runs about the same as a PMDC motor, AND NOT at all like a brushless DC (BLDC) motor. the types are VERY DIFFERENT. IN a shunt motor the field strength depends on the applied field voltage, while in a series DC brushed motor the filel strength depends on the armature current. So the series DC motor can have a very strong starting torque! For the SHUNT DC motor that starting torque boost is not available, and so the torque is about the same from start to max speed.
(EDIT)
Warning: If the shunt field current fails in a seperatly powered field motor, the armature counter-EMF drops off and the motor will draw a lot more armaure current and spin MUCH FASTER. That can be dangerous, like a clutch exploding on a dragster, only much worse.
JohnSan
Joined Sep 15, 2018
141
Warning: If the field current fails in a series motor the armature counter-EMF drops off and the motor will draw a lot more armaure current and spin MUCH FASTER. That can be dangerous, like a clutch exploding on a dragster, only much worse.
I think this thread came to a conclusion some time back.
Your last paragraph is completely wrong. It applies to shunt motors, not series motors.
LikeTheSandwich
Joined Feb 22, 2021
216
When looking into controllers for motors for RC cars years ago, I did find several of those motor controllers that could handle either three phase BLDC or brushed motors. Additionally it was mentioned on one website that you could rectify the output from all three by building a full bridge rectifier to make it work with a brushed motor if you really needed to. But definitely not for the voltage I'm looking at, and the rectifier option would be so wasteful at these powers.
Yeah, I think I have enough information to get something working. I was specifically hoping to find a controller designed to control the armature and the field windings because one thing that I've learned about motors is that when you have windings on both sides, you can utilize field weakening at high RPM to increase motor speed and efficiency, but learning the nuance of that is beyond me ultimately. At least for right now.
LikeTheSandwich
Joined Feb 22, 2021
216
Not sure if you got a sufficient answer but to clarify, a standard brushed DC motor only needs positive and negative. There are armature windings inside the motor that connect the brushes, so as it spins, the armatures will disconnect from the brushes and then reconnect on the other side, so that current flows in the same direction always. A brushless motor, because it does not have the brushes, has to electronically control the direction of the current flow. To increase the efficiency of this and to be able to easily control the direction, they use three wires. For example if it is in position A and you want clockwise rotation, it'll reverse polarity on position C since that's the closest alignment, then standard polarity on position B, as that is the next in order. Then it'll do reverse polarity on A, then standard on C, etc. by being able to reverse polarity, the power and magnetic alignment are never more than 1/6 of a rotation away from each other. And with additional coils and additional magnet poles (not always cost efficient, but sometimes for high precision or high performance applications they will do this), you can do much better than 1/6th. The most common setups I have seen have 8 magnets, alternating in polarity, and 3 coils.
28,517
Thanks for the reply. I was looking at that from amazon, looks like it's less than $200, it's listed as a 110 volt model though. Would it work from 72 volts DC? Also how are you suggesting I power it from an incline circuit? I'm not sure I understand. Also what do you mean by PM field not wound? You mean permanent magnet instead of having an actual field winding? This motor is very old, I think they stopped manufacturing it like 15 years ago or more. I'm not sure if it was clear in the picture, but there's both Field and armature connections. F1/F2 and A1/A2. But am I right that if I just apply an appropriate current to the field winding, it would then kind of work like a permanent magnet brushed motor? And then I could just worry about applying a brushed motor controller to the A1 and A2 connections? Also that controller looks like it would be woefully underpowered, it really doesn't look like it can handle the 60+ for this motor.
Am I understanding what you're saying correctly? That what I said earlier, if I excite the winding, then it would function kind of like a brushed DC motor? If so, that controller says brushless, so I'm not sure if it would work necessarily? But I'm sure I could find a brushed controller or something, I just wanted to verify if it would function similar to a permanent magnet brushed motor if I was to excite the field winding. So just to verify, are you agreeing with that assessment?
MAX needs tp look st the tag on the motor: It gives the shut wound field voltage and current. So it is not PM.
Converting a wound firld DC motor to a PM DC motor would be a complicated big project that would be rather expensive as well.
