Sequential LED Turn Signals
sghioto
Joined Dec 31, 2017
8,765
As this gets more complicated I'm starting to consider just replacing the failed aftermarket modules and hoping for the best.
It's very possible those modules can be repaired.
I would suspect those mosfets marked Q1, Q2 and Q3 are probably defective and can be replaced.
Those mosfets are rated 2.5 amps max.
So it depends on how much current those LEDs draw before deciding on a replacement.
B52_Chief
Joined Sep 2, 2025
20
There are SIX total leds that need to be driven.
If you replace the CD4025B with a CD40106B Hex inverter, you can drive mosfets for all six LEDs from the CD4017B.
Sounds like that might be simpler (i.e. fewer overall compnenents). One PCB is preferable to two. Is there a way to run the Lt turn and Rt turn signals through one circuit, sharing the priciple components, then spliting the 2 groups of three LED's.?
I've down laoded your diagram, and I'm reading up on mosfets.
Can I use a BC335 transistor in place of the relay? That would free up som board space.
B52_Chief
Joined Sep 2, 2025
20
Guess I need to amp the lights... But of course, that's the one gizmo I don't have. Sugestions on a reasonably priced meter for a rookie? I know how to use it I jus dont own one.
sghioto
Joined Dec 31, 2017
8,765
The relay can be replaced with transistors or mosfets and one board is sufficient.
Complete circuit, IC4 replaces the relays.
B52_Chief
Joined Sep 2, 2025
20
THANKS!!! Now I can order parts with some degree of confidence.
I'm thinking it might be easier to use plain perforated board rather than the GP PCB's I've bee using
BTW - the LEDs draw 0.024A on Hi and & 0.006 on Lo. I have a perfectly usable meter. I just had a bit of brain flatulance.
The bad news - I'm pretty sure my Jeep batteries are shot. They are 4-yr old, high-end, deep-cycle, Intersatates and they've had a hard life. I'm re-recharging them for a second test. It's always something...
AnalogKid
Joined Aug 1, 2013
12,301
Not sure you need IC4. It basically is an inverter, and you already show a protected and filtered input; a 2N7000 would do the same thing. You have IC4 configured for a threshold voltage of 6 V, while a 2N7000 would come on at around 3 V. Does that matter?
ak
sghioto
Joined Dec 31, 2017
8,765
Plug the RED probe into the jack to the right of the Black probe.
Leave setting on ma/A and read again to verify please.
Is the white lead on the LED for dim?
