Purpose of cascaded schmitt trigger in Hall sensor
sitheesh
Joined Jan 3, 2023
9
Hi, this is the functional block diagram of a hall sensor IC. Can anyone please explain what is the purpose of these schmitt trigger followed by another trigger? Is single trigger cannot be able perform the function required?
ericgibbs
Joined Jan 29, 2010
21,569
hi sit,
The 1st is a Comparator, with hysteresis, the 2nd is a Schmitt triggered by comparing input voltage against a Vref voltage.
E
Ian0
Joined Aug 7, 2020
13,278
I think that the first is a mislabelled differential amplifier. That would make a lot more sense.
What‘s the point of a comparator if its input can only be 5V or 0V?
38,806
I agree with Ian0.
It makes little sense to have a comparator with hysteresis (a Schmitt-trigger) in series with another Schmitt-trigger.
I think the amp ahead of the Schmitt-trigger is supposed to be a differential amp (reverse the + and - input polarities) to sense the sensor differential signal, which has a DC offset.
The "Offset Cancel" block refers to the function the differential circuit performs.
drjohsmith
Joined Dec 13, 2021
1,650
Also
remember, its a picture done to describe the action of the chip,
drawn by an artist .. not an engineer,
its purpose is to easily convey that the input detects a difference, and the output has been made a good edge,
Id be surprised if you could look at the silicon if there were these actual components.
