Bypass capacitor purpose?
Homebrew1964
Joined Nov 22, 2024
289
Can someone please tell me what function C2 plays in my circuit ?
All i can see is that it gives additional gain, is there any other reason for it being there?
WBahn
Joined Mar 31, 2012
33,352
Without C2, what is the gain of the circuit?
How does making the value of RE smaller affect that gain?
What happens to the impedance of the RE. C2 combination when they are in parallel as C2 is made reasonably large?
Homebrew1964
Joined Nov 22, 2024
289
I should stress i havn't actually built the circuit so i have no idea what the gain is...i was just curious about what that C2 actually does, i see lots of common emitter amplifiers using it.
38,952
So do you know how the emitter impedance value affects the circuit gain, i.e. how is the gain value of that circuit is calculated?
Once you understand that, you can answer your own question.
Homebrew1964
Joined Nov 22, 2024
289
I have no idea, i am doing the suck it and see approach (put some values in and see what happens) i really don't have much math knowledge other than ohms law.
WBahn
Joined Mar 31, 2012
33,352
For that particular amplifier configuration, the gain is basically the ratio of Zc/Ze where Zc is the impedance between the collector and its supply and Ze is the reactance between the emitter and its supply.
You are limited by how much DC gain you can tolerate, otherwise the amplifier will saturate even with no input signal due to the bias network. That limit is often a lot less than the gain we want at the signal frequencies of interest. So we design the emitter impedance such that it starts of at a fairly large value at DC (chose to put the quiescent operating point where we want it, which is usually somewhere near the middle of the rails) but that it's starts getting smaller as the frequency increases.
That's what the bypass capacitor does. At DC, it looks like an open circuit, so the emitter impedance is just the resistor. But at high frequencies, the capacitor looks very close to a short, which still looks like a short when you put it in parallel with the resistor. The RC time constant determines the frequency at which this transition happens and to choose it to be somewhere between DC and the bottom of your signal frequency range.
LvW
Joined Jun 13, 2013
2,066
I am "afraid" that - if somebody really wants to understand the role of RE and C2 - he has to learn the basics of negative feedback (and how negative feedback determines the gain)
28,612
Really, it is basic circuit theory! During the negative slope of the output waveform, the emitter resistor is in series with the load. The "increase in gain" is because of the effective reduction of the emitter series impedance by the capacitor C2
LvW
Joined Jun 13, 2013
2,066
Because no parts values are given for the circuit under discussion, I think it is helpful (and necessary) to add that the mentioned approximate gain expression (Zc/Ze) is valid for |Zc|>>25mV/Ic only.
For C2=0, this condition simplyfies to Re>>25mV/Ic.
35,309
For starters, the drawing of the input and output voltage waveforms are drawn incorrectly.
The common emitter amplifier is an inverting amplifier. Hence the output waveform needs to be inverted as shown above.
35,309
In order to have a deeper understanding of how transistor circuits behave, start with a basic common emitter configuration and learn how the base bias voltage affects the DC operating point of the transistor. You can do this with real components or with a circuit simulator.
From this, you can determine the current gain of the circuit.
35,309
The question is: What is the purpose of the emitter resistor, R3?
R3 introduces negative feedback. With more positive input at the base, the current through Q1 increases. The voltage at the emitter rises and hence the base-emitter voltage is reduced. This opposes the attempt to increase the transistor current. The end result is lower AC gain.
Now what happens when you put a capacitor on the emitter? The capacitor tries to keep a constant voltage on the emitter. Hence the emitter is now shorted to GND from an AC perspective, restoring the higher AC voltage gain.
The value of the shorting capacitor is important. It has a time constant when R3 is taken into account. Hence the capacitor only comes into play when the AC frequency is above a certain frequency. You choose the value of the capacitor depending on where you want the transition from low AC voltage gain to higher gain.
The take away here is: the function of the emitter resistor R3 is more important than that of the bypass capacitor.
The emitter resistor:
  1. introduces negative feedback
  2. introduces DC stability
  3. makes it less temperature dependent
  4. improves linearity to AC voltages
  5. makes the circuit less dependent on transistor specifications
The bypass capacitor allows you to restore the voltage gain above a given frequency.
Homebrew1964
Joined Nov 22, 2024
289
Thanks for that explanation MrChips...
38,952
The disadvantage of that circuit with the emitter capacitor bypass, is that the gain is temperature sensitive, and the output can become non-linear at the frequencies where the capacitor totally bypasses the AC signal.
To stabilize the high-frequency gain and reduce distortion a resistor can be added in series with the capacitor.
The high-frequency gain is then mainly determined by the relative values of that resistor in parallel with the bias emitter resistor and the collector resistor.
