Psu transistor please help
Fishtacoburritosupreme
Joined Dec 12, 2020
6
Ugh I truly don't know how to search for this particular psu is there any key I could use to find it? All I found was a manual nothing else don't know if it's of mScreenshot_20201212_090606_com.android.chrome.jpguch help
paulktreg
Joined Jun 2, 2008
851
They tend not to release their schematics so I'm pretty sure you won't find one on the internet.
If somebody has one perhaps they can take a look?
sagor
Joined Mar 10, 2019
1,056
From the picture, I see only 2 legs and an insulating strip behind it. That suggests a diode of some sort, or perhaps even a thermal switch/fuse. If a thermal switch, is may have gone open like a fuse, stopping the circuit. Try to find the part number. Remove it and do a diode test with a multimeter to see if it is a diode or is "open" or "shorted"
SamR
Joined Mar 19, 2019
5,549
It should be stamped on the component. Can you take a closeup of just the component? Also of the area of the PCB where the component is placed.
SamR
Joined Mar 19, 2019
5,549
It is clearly marked on the PCB D23 which is a diode and the component markings indicate BY-C15 which is a Hyppefast power diode. extension://nhppiemcomgngbgdeffdgkhnkjlgpcdi/data/pdf.js/web/viewer.html?file=http%3A%2F%2Fpdf.datasheetcatalog.com%2Fdatasheet%2FNXP_Semiconductors%2FBYC15-600.pdf
The PCB markings in the other spots are for transistors. Without them or a schematic specifying them you are outta luck.
Joined Dec 12, 2020
6
OK first of all thanks for your answers, now OK, if you look to the sides of that hyppefast diode you mention theres a silhouette of the transistors that were there clearly bigger than than that, I remember the components had 3 legs.
SamR
Joined Mar 19, 2019
5,549
Techohead
Joined Nov 23, 2020
11
Please can anyone help me determine what type and model of transistor this psu uses(voltage, amp, etc), the one it had were removed and I have no idea what Trans use D:
They have a TO247 case & could be FETs, type SPW20N60C3 20.7A 650V Check if the device driving them is a transformer, in which case they could be transistors, of in IC design to drive FETs. the datasheet of the device will tell you.
