MisterBill2
- Joined Jan 23, 2018
- 28,078
In the instance we were discussing there were NO COPPER PLATES. The portion of the circuit claimed to be coupling to"ground" was a very short length of wire at the top of a coil that was several inches away from the battery negative connection that was claimed to represent "ground". so the capacitance between the two points was very small. The capacitance that I was referencing was between the three turn collector coil and the bottom of the secondary coil that it was wrapped around. In classical Blooper systems, this would seem to be providing the collector to base feedback to get things started. And until oscillation starts there is no current flowing in that secondary coil to magicaly cause current to flow as feedback to the base.
Of course, in a blooper circuit there is no telling as to whatever coupling may be the result of component proximity or power source internal resistance.
