Problems with phased array
Sabro
Joined Jul 22, 2022
69
Good morning, I have a project with phased arrays, I would like to create areas in the space in which there is a single pulsation frequency for example 5 Hz, and in another area next to it it must pulse at 8 Hz, to do this I would like to use a phased array with 16 patch antennas, in which there is an 800 MHz carrier pulsed at 5 Hz or 8 Hz, so to avoid interference between the two areas is it better to use a single 800 MHz carrier or two carriers of 700 MHz and 800 MHz??
28,636
Before radiating any pulsed signals, at least in the USA, you need to see the rules about radiating RF. Check with the FCC. In most parts of the world, radiating RF signals is regulated.
Sabro
Joined Jul 22, 2022
69
no no it does not concern exposure to humans or other living beings, it is a musical project, in fact the array is very directive and will not involve living beings
Sabro
Joined Jul 22, 2022
69
Absolutely maybe. Phased arrays work with propagating signals because you need phase stable fields to be combined. 1 meter is ~3 complete wavelengths at 800MHz. That's the radiative near field.
https://en.wikipedia.org/wiki/File:Phase_array_sweep.webm
https://www.analog.com/en/resources...cles/phased-array-antenna-patterns-part1.html
checked carefully and for an array with planar patch antennas 50 centimeters wide on each side, the Fresnel zone starts at 1 meter, this is the suitable zone, so I confirm that my receiving antenna will be 1 meter away from the array, you also have to calculate the size of the array, the wider it is the more the Fresnel increases
28,636
First, my comment was about the legal aspects, not about human or animal safety. RF signals at different pulse rates? Somehow related to music??
I suggest light from infra-red LEDs, and sensitive photo-sensors. That wil nbe much simpler and also a lot less expensive.
If you are hoping to invent a musical instrument using RF to control pitch and volume, it has been done MANY years ago, it is called a THEREMIN, invented in the era of octal elelctron tubes. Also a whole lot of wonderful sounds on a device created by some guy named "MOOG."
