PNP transistor to amplify square wave signal received at its base
MrsssSu
Joined Sep 28, 2021
267
Above is the load power
Hi People,
I created this npn transistor circuit and it works fine. So basically, it receives this square wave impulse (0 to 2V) and send it to the 10 Ohm(Load) to be amplified to become (0 to 10V).
Question: How to simulate the same way (Load Power Output should be about same) but using pnp transistor because I need the green highlighted part in the diagram to be absolutely grounded ( 0 V at all time) :) ? Probably can simulate a simple LT spice circuit to demo :)
Thank you for reading :)
ericgibbs
Joined Jan 29, 2010
21,649
Hi MRsss,
I would recommend every time you post a LTS sim, please post the asc file, so that we can run the sim.:)
E
Update:
Post the asc file
Alec_t
Joined Sep 17, 2013
15,168
The 2N2222 in post #1 would burn out. Don't forget to choose a PNP transistor which can comfortably handle the 1A load current.
