I assure you that people could hear my Fender Tremolo amp in the back row, and even down the street. And my knobs only went to 10.That sound is what people in the venue hear, not the sound from the individual amplifiers.
Try a LM567 Tone Decoder.Please SKL001 can u explain what components you used to remove 60hz in your project please. That will be really helpful. I know I have got off on the wrong foot with your community therefore they will only discuss subject rather than object... Understandable. But I really just need to be pointed in the right direction and I can take it from there. Can you please explain how you managed to remove 60hz, what process did you use, which components, much appreciated, many thanks Jonty
Not to mention more effective.But as other have suggested, fixing the cause of the hiss would still be cheaper than designing a electrical circuit to remove noise.
But not if your band was looking to be professional. Even the smallest dance bars around here use a mixing board for the band.I assure you that people could hear my Fender Tremolo amp in the back row, and even down the street. And my knobs only went to 10.![]()
Lm567 tone decoder YES thank you. Than you one and all for all of your help, comments, ideas and inspiration my favorite EEA the video of the Russian last explaining sound waves that was epic! Much appreciated community thanks JontyTry a LM567 Tone Decoder.
http://pdf.datasheetcatalog.com/datasheet/nationalsemiconductor/DS006975.PDF
Personally I think you need a computer and software and not a hardware fix. Have you done a simple search for "how to remove hiss/noise from audio files" But as other have suggested, fixing the cause of the hiss would still be cheaper than designing a electrical circuit to remove noise.
NOTE: Please disregard this post. I was "out-of-my-head" when I wrote it!Thanks again for all your help community. Sorry for taking up so much time on one thread!
However, once again I am asking to borrow your knowledge.
Can you explain to me what the following means in layman's terms. My education in circuits is extremely limited.
"The LM567 and LM567C are general purpose tone decoders designed to provide a saturated transistor Resistor switch to ground when an input signal is present within the passband. The circuit consists of an I and Q detector driven by a voltage controlled oscillator which determines the center frequency of the decoder. External components are used to independently set center frequency, bandwidth and output delay."
Many thanks, Best Jonty
The LM567 is not a filter-- bandpass, band-reject, lowpass, highpass, or otherwise. It does not "pass" some frequencies and reject others, not does it modify the signal it is fed in any way. The LM567 is simply a tone detector, as @Audioguru indicated: when a signal within a certain frequency range is presented to it, its output turns on. Otherwise, the output is off. And that's ALL it does.A typical LM567 circuit, depending on the components selected, will pass(passband) a frequency, or range of frequencies to an output device(such as speakers). All other frequencies(sound) will be filtered out.
My bad. You are absolutely correct. It's been so long since I used one. I'll have to be a bit more careful when offering help. I appreciate the correction!The LM567 is not a filter-- bandpass, band-reject, lowpass, highpass, or otherwise. It does not "pass" some frequencies and reject others, not does it modify the signal it is fed in any way. The LM567 is simply a tone detector, as @Audioguru indicated: when a signal within a certain frequency range is presented to it, its output turns on. Otherwise, the output is off. And that's ALL it does.
It is not applicable to what the TS is trying to accomplish here (whatever that is).
You are trying to reinvent Dolby.Actually it's not the feedback it's a hiss that is the problem
I suspect he just needs to use an equalizer and probably to spend his dosh on a good recording engineer.I suspect that the hiss is produced by a "pedal" or a microphone preamp for vocals with an old poorly designed circuit.
Especially when you consider that removing hiss has been worked on since the beginning of recorded audio, and even today’s state of the art (software) isn’t perfect. The odds of a successful DIY device from a novice are not good.I suspect he just needs to use an equalizer and probably to spend his dosh on a good recording engineer.
