Help needed please with plug connections
Annie Vaws
Joined May 1, 2026
32
Hello everyone
Could you help me please. I am trying to figure out which terminal is + and - on these cheap Chinese plugs. I don’t have a multimeter.
Anyone help please?
Thank you
Annie
Jon Chandler
Joined Jun 12, 2008
1,647
There is no defined positive or negative terminal. There's the center contact and sleeve – typically, the center contact is positive and the sleeve is negative, but this isn't always true.
The other contacts are a switch. Usually, the switch contact opens when the plug is inserted, often used to disconnect an internal battery when a power supply is connected.
Best bet is to use a DVM to beep out the contacts and to determine polarity with whatever power supply you plug into it.
dl324
Joined Mar 30, 2015
18,473
Welcome to AAC!
Assuming center positive. + is terminal on the back. If you look inside of the jack, you'll see a contact that will touch the barrel of the mating part; that will be -.
In the image below, + is terminal #1, - is terminal #2.
