Sega GameGear Charging Pack Help Needed!
bluejonny
Joined Apr 27, 2023
Hi Everyone
I'm new here, and hoping I have posted this in the right place! I am wondering if I could get some advice for a complete novice when it comes to troubleshooting. I can do basic things like use a multimeter, change components and I am at a good level with soldering. However I have been pouring over this board now and it's really irritating me! The board is for a rechargeable battery pack for a Sega GameGear (GG). It won't power a GameGear as the voltage when under load drops from 7.5v to around 2-3v.
Power is always present at the connector (that's correct apparently according to some research I did). When charging you switch the unit to ON which activates the charging circuit. The switch is not used for any other purpose it just turns on the charging. The Orange LED comes on, and after around 6 hours of charging, I disconnected it and tried it in the Gamegear - but nothing. Incidentally, the orange LED had not gone out, but the battery was warm and when measured was coming in at around 8v.
Some notes -
1. I am charging with an official Sega power adaptor that works fine (can power up a GG no problem)
2. Three caps have been changed. Standard practice for me on this type of old board. I just do it! They are correct V and uF and inserted the right way.
3. I tested the voltage at the output lead (blue and yellow wires) and when it's not under load (so not connected to the GG) it measurers 7.5v-7.8v
4. As soon as the GG is connected to the pack, the voltage drops to anywhere between 1.5v - 2.5v, again, measured at the output solder points. Remove the lead from the GG and the voltage jumps back up to 7.8v
5. The fuse is good.
6. I have tested and inspected tracks, I cannot see any breaks or corrosion.
One thing I did noticed is that the component at C6 looks a little brown on top almost looks a tiny bit melted?
So, this is far as I can go. If anyone can help with next steps, I would be eternally grateful!
Thankyou!
J
bluejonny
Joined Apr 27, 2023
Welcome to AAC.
Why don't you suspect the battery as the faulty component?
That's a very good question. Assumed as it was brand new, charging OK and holding voltage it would be fine. but now you have me doubting it, I will try and connect it directly to the GG and see what happens!
bluejonny
Joined Apr 27, 2023
Hi Everyone - Battery is good. Direct connection powers the GG no problem. So, the board. Any suggestions on testing please, or what to do first?
Reloadron
Joined Jan 15, 2015
7,979
I have a box around here somewhere with old Sega stuff including a complete game. Give me a day or two to dig it out and I'll see exactly what I have and if it could be of any use to you I will send it to you free gratis.
Ron
