Piezoelectric signal to pulse
28,279
This is the plan.
And by your reaction i fear that my plan is dumb lol
Not s dumb plan at all, but rather not understood by many of us. The difference between the 7400 series and the CD4xxx series is that the74 00 is a replacement for TTL, running at TTL voltage of 5 volts, while the CMOS CD series can work very well at 12 volts, and some of them even higher. So they are not always plug-in interchangeable.
And for whole light strips running on 12 volts, there will need to be some sort of driver interface, depending on the current the LED strips require. We don't know that so which transistor to pick is unknown.
spokenwurds
Joined Aug 6, 2023
43
Attempt to clear up the noise of my inaccuracies and knowledge deficiencies.
Light Switcher Project
WS2812B LED Strip
Voltage: DC-12V
LEDs: 120leds/m
Color: White
WS2812B Datasheet
Apparently i should have read the DATA SHEET before beginning this journey.
The data-sheet states 5V max. I’m still trying to understand why the label says 12V.
Project intentions:
Create 5 controllable relays for DIY LED light fixtures.
Important relay control parameters:
Relays will be triggered by 2 independent, manually selectable pulse circuits with “if achievable”, a LEF Fade Out circuit.
  1. Piezo pulse generating circuit much like a Piezo Drum Signal Conditioning circuit. Reference circuit.
  2. Standard Timing Pulse Generator “555” with potentiometer pulse rate control.
  3. Potentiometer controlled LED “fade out rate” circuit paired with circuit 1 or 2. Optimal control of this circuit would be to omit potentiometer & link partnering circuit’s pulse rate to fade out rate.
BobTPH
Joined Jun 5, 2013
11,648
A WS2812b strip requires a controller. You cannot simply give it power and have it light up, you have to transmit 24 bits of data for each LED on the strip with specific timing. A microcontroller or other programmable device is the only practical way to do that.
spokenwurds
Joined Aug 6, 2023
43
this is what came in the bags i recieved. Seems like only two channels. All White SMD LEDS
28,279
OK, there is some serious confusion between what I see in the picture and what BOB is describing. Not just a bit different but a HUGE DIFFERENCE.
The strips in the picture in post #85 are rather different from what BOB is describing.
The good news is that thencontrol scheme for a strip as shown does not require any digital processor to generate a bitstream to control individual LEDs. The light intensity can be controlled over a wide range by adjusting the current, which is controlled by changing the supplied voltage. So we are back to what has already been discussed, and we still do not know the exact current. But we do know the power supply voltage and we have a reasonable grip on the switching scheme. And a fair clue that the description does not match the reality, which in this instance is good.
spokenwurds
Joined Aug 6, 2023
43
Hi there,
So it turns out that the packaging label said WS2812B which i took for fact.
I ordered the lights a over a year ago when i began this project. But shortly after my eldest son was having difficulties in school on many levels. He was assessed by a neuropsychologist and was codes for ADHD and Autism which lead to a very difficult year of many adjustments. I paused everything for him.
Now i’m able to get back to this, but some details i had were fuzzy.
i went through my emails and found the original invoice and the lights are as follows:
SMD 3014 LED Strip 5m - 8mm Width 120LED/meter DC12V
Electrical :6w/9w/12w/17w/m , DC12V
This is what i was able to locate on the particular LED
CodeColorTypical Forward CurrentMax Forward CurrentTypical Input VoltageMax Input VoltageTypical LmMax Lm
4012Cold White30mA35mA3.3V3.6V3600 mcd4800 mcd
sghioto
Joined Dec 31, 2017
8,751
Or replace the transistors with logic level mosfets like the IRLZ44N and eliminate the resistors as well.
spokenwurds
Joined Aug 6, 2023
43
Since you have ordinary white 12V LED strips with current-limiting resistors in them, use this circuit:
Now i just need to understand the math enough to convert the piezo circuit control components to output 12v instead of the 5v it’s currently set to.
So much information to process and then leverage haha. Thank you for the patience.
BobTPH
Joined Jun 5, 2013
11,648
A MOSFET can be used as a switch to supply 12V to the strips when the 5V signal from your pulse circuit is high. This is not an amplifier, it only has two states, off and on. An amplifier would take any voltage between 0 and 5 and turn it into a corresponding voltage between 0 and 12. You do not need an amplifier.
MOSFET as a switch
spokenwurds
Joined Aug 6, 2023
43
A MOSFET can be used as a switch to supply 12V to the strips when the 5V signal from your pulse circuit is high. This is not an amplifier, it only has two states, off and on. An amplifier would take any voltage between 0 and 5 and turn it into a corresponding voltage between 0 and 12. You do not meed an amplifier.
MOSFET as a switch
Okay, so the 555 timer & CD4017 works fine with 12 volt and eliminates my voltage drop to the LED strips.
But the piezo is locked to 5v as per referenced and test circuit designed for a piezo drum circuit. using a different component as you’re suggestion would be placed where at the end of my piezo circuit and bump it up to the necessary 12v spike to pulse the clk in the CD4017?
BobTPH
Joined Jun 5, 2013
11,648
You cannot supply the strips directly from the chips! The current they can provide is barely enough to light one LED.
Get over it, you need to use a transistor switch.
Audioguru again
Joined Oct 21, 2019
6,826
The LED strips have 120 LEDs per meter in series strings of 3 (30mA per 12V string) and the strips are 5 meters long. Then the current for each 5 meters is 6A. IRLZ44N Mosfets can drive each 5 meters fine with a 5V signal input.
The CD4017 IC will turn on only one 5 meters LED strip at a time.
28,279
That 35 mA Max was for a single LED. If you power a whole 1 meter strip with 120 LEDs arranged as 40 of the 3 LED strings plus a resistor you will still need a driver circuit able to handle that current, which might be almost 3 amps.
I did not see any circuit that limited the sensor voltage to5 volts, so it may have been in a link I did not follow, if it was a youtube link.
Where does a 555 timer get into the discussion??? What it it doing for the application?? If a timer is required us a CMOS IC timer that can handle 12 volts easily. MC4538, MC14538, or others.
spokenwurds
Joined Aug 6, 2023
43
Sweet that’s awesome info thank you
