Piezoelectric sensor based BCG measurement
yashbakka
Joined Jun 11, 2026
5
Hi, I'm building a Piezoelectric (PVDF) sensor based BCG measuring circuit that will be used to extract HRV and RR. It is supposed to lay underneath a mattress, and measure these using the recoil in our body due to heartbeat and also our breathing rate. The sensor I'm using is the SML-300. No exact datasheet to be found, the internal Capacitance is 2nF.
Ive attached the image of the circuit i made. Small difference, Im not using the VREF rail since i made that because the STM32 cant handle negative voltages but for now im using a Saleae logic analyzer to measure voltage change.
Pressing the fully insulated film (tape + silicone strip) → absolutely no change in the output. No spike, nothing.
The only time I get a response is touching the bare exposed electrode with a finger — and that's a clean 50 Hz waveform, i.e. mains coupling through my body into the high-Z node, not a mechanical signal.
So I have no evidence of any real mechanical piezo response — everything I've seen appears to be electrical mains pickup via bare contact. Ideally a press through the insulator should generate charge and show a spike, and it doesn't.
A second oddity I can't explain: increasing R4 (the gain stage's input-to-VREF resistor, 1k → 100k → 1M) makes the decay transient look more prominent (see the two attached traces). By the non-inverting gain formula (1 + R5/R4) increasing R4 should reduce gain toward unity, so I'd expect the signal to shrink, not grow. Not sure if I'm seeing a time-constant/settling effect rather than real gain, or something else. Image 2 is with R4 = 1K ohms and image 3 is with R4 = 1M ohm.
1. Why does increasing R4 (which should lower the gain) make the transient more visible, not less? Time constant / DC settling effect, or am I misreading the topology?
2. Bigger issue: why would a mechanical press through insulation produce zero output while only bare-contact 50 Hz shows up? Does this mean my sensor isn't mechanically coupling/working, or is gentle finger pressure just too weak/slow to generate detectable charge through a charge amp with a 0.17 Hz HPF?
3. For bare PVDF on a high-Z charge amp, is a grounded foil shield (insulated from electrodes) the standard fix for the 50 Hz pickup? Any grounding gotchas?
4. How do people bench-test PVDF mechanical response in a way that isn't contaminated by body-coupled mains? (Battery power, Faraday cage, mechanical tapper, signal injection?)
Any help is appreciated! Thanks!
yashbakka
Joined Jun 11, 2026
5
It might help if you explain some of the terms you are throwing around, particularly all of the acronyms.
My apologies!
PVDF is the type of Piezoelectric sensor ive used (stands for Polyvinyl DiFluoride if im not wrong)
HRV - Heart Rate Variance, basically the time in between two heart beat pulses (J peaks on the waveform)
RR - Respiratory Rate, the rate at which we breathe.
BCG - Ballistocardiography
VREF - Reference Voltage
SML300 - the model of sensor im using, made by Legact film sensors.
Please let me know if any more information would be helpful! thanks!
yashbakka
Joined Jun 11, 2026
5
Can it handle small analogue signals? The name implies it's for measuring digital signals, not analogue ones.
yes, it has an analogue mode, it can measure voltages as low as 1mV
update: i probed at U3A Pin 1 (the output of op amp A inside the MCP602, and i can see voltage spikes when i tap the sensor kept inside a silicon insulator sheet. so the sensor is fine, so is the software. The issue is the connections around the MCP then I assume. also another issue, yes it's showing voltage spikes due to pressure when i probe Pin 1 but when I zoom closer, the whole thing is once again overshadowed by the 50z mains hum. Do you see any issue with the circuit schematic, connections and parts wise?
thanks!
28,516
Consider the difference in magnitudes between the sensor signal and the mains frequency pickup. There may also be other causes as well.
My own experience with PVDF transducers is that the very high impedance makes the mains radiation pickup much greater than the PVDF signal. So we had the amplifier circuit within about half an inch of the PVDF sensor. A VERY SHORT interconnect was the solution we found.
28,516
To clarify what I meant by VERY SHORT, the PCB trace from the PVDF sensor to the FET input of the amplifier was about 4 millimeters long. That sensor was used for sensing automotive crash impacts.It was in contact with the auto body metal. So while the signal was just a few millivolts, the path was short, so the noise pickup was minimal.
AND, the impedance level of that circuit was quite high. AND the shunt capacitance was very small.
Irving
Joined Jan 30, 2016
5,195
From a research paper comparing PVT and PVDF sensors.... " ECG signals were band-pass filtered in the 0.5–40 Hz band using a 4th-order zero-lag Butterworth filter. A comb notch filter was then applied to remove 50 Hz powerline interference and its higher harmonics. "
This needs to done very early in the amplifier chain to avoid saturating the system with 50Hz interference while amplifying the pvdf signal
yashbakka
Joined Jun 11, 2026
5
oh wow. that helps a ton. i tried to make every connection as short as possible (im testing the circuit on a breadboard as of now so i just cut all the components and wires as short as i could) and it helped a lot! although, i ruined one of my sensors because of the soldering iron touching the outer shielding material (a metallic cloth like material i ripped out of a different sleep band) and it ended up burning the connection with the ground terminal. i had to use a new sensor because of this, and the new one has a very long connecting wire to the amp as of now. ill shorten that. so far now 50Hz signal, i managed to derive heart rate and respiratory rate but im still working on HRV. i have an oscilloscope inbound in a few days so hopefully thatll help me view j peaks clearly! thanks for the help!
yashbakka
Joined Jun 11, 2026
5
oh i see. my bandpass is currently 0.16-17Hz but I'll look into bumping the low pass up to 40 if thatll help see HR more clearly. no idea what a comb notch filter is, so I'm going to look into that now. thanks Irving!
28,516
For temperature sensitive elements I recommend crimp connectorsas the way to avoid heat issues.
(added much later) PVDF has two properties that make it very difficult to work with, in addition to the obvious properties that make it hard to work with: It has a low mass density (low specific heat), so that it does not take much heat energy to raise it's temperature quite a bit. In addition, it tends to change physical properties with relatively small temperature properties.
That makes it a mizerable piezoelectric material to work with, despite it being a qood piezo-electric generator.
