Obtainig Low Pass Filter's output signal as square edge.
Alex_Khan
Joined May 27, 2020
60
Hello
I am demodulating a signal. In which Low Pass Filter (LPF) is used to attenuate high frequency modulated signal. The input and outup of LPF is shown. The problem is the edges of LPF output signal is not square [as shown in figure] which result in poorly selection of lower and upper switching voltage of schmitt trigger [which retrieve orignal message signal]. So,i need the output of LPF to be exactelly square edge , which facilitate me to accurately select lower and upper switching voltage of schmitt trigger.
I keep on changing the cutoff frequency of LPF to obtain my required result but failed. If any one would suggest me any solution that result in obtaining square edged LPF output.
Thanks.
KeithWalker
Joined Jul 10, 2017
3,625
There is not enough information in your posting to allow me to try to give you an answer.
Obviously, the output from the low pass filter will not contain the rejected high frequency components of the signal so the waveform will have slow rise and fall times.
Why are you not using the unfiltered signal to trigger the schmitt trigger?
Regards,
Keith
Alex_Khan
Joined May 27, 2020
60
Hello
Thanks.
Thanks for your response!
I know that LPF do not give exact square wave output ,however i would like to know what extra design at output of LPF should i add to get exact square edge output.
Alex_Khan
Joined May 27, 2020
60
Low-pass filters do not produce outputs with square edges.
Hmm , well thanks for your appreciation :)
i know that i cannot get square edge from LPF output. I would like to know, extra circuit that i need at LPF's output to get square edge.
Looking forward!
Papabravo
Joined Feb 24, 2006
22,115
Looking forward!
There isn't any. Square edges and LPF are requirements in CONFLICT!
OBW0549
Joined Mar 2, 2015
3,565
There's your problem: you're focusing on the wrong thing. Somehow you've got the idea that the solution to your problem is to somehow get a "square edge" out of your LPF or some circuit connected to it, whereas the REAL problem is that your LPF doesn't adequately attenuate your carrier frequency relative to your modulation frequency. A 2- or 3-pole filter, instead of the single-pole filter you show, would do a lot better job and produce a much more usable input to your Schmitt trigger circuit.
I would suggest you do some reading about single- versus multi-pole filters, and about different filter characteristics (Butterworth, Bessel, Chebychev, Ellliptic, etc.) before going further.
Alex_Khan
Joined May 27, 2020
60
Regards,
Keith
Well thanks for your response and explaination.
Moreover, i have attached block diagram of my system , which i am following. I hope this will answer that why i am using filter before schmitt trigger .
I can retrieve message signal by chosing variables of schmitt trigger , but there is slight difference between orignal message signal and retrieve signal at demodulator side[ attached].
OBW0549
Joined Mar 2, 2015
3,565
There will ALWAYS be a difference; it's unavoidable. You need to accept that, and deal with it.
Alex_Khan
Joined May 27, 2020
60
Well thanks sir for sharing your valuable knowledge and suggesions. Your comments always motivate and show me right direction.
I will try to study and design high order filters [as you suggested] and will see if it work !
Stay safe & blessed !
Deleted member 115935
Joined Dec 31, 1969
A square wave has harmonics of the fundamental, up to "infinity" ..
If say you have a 1 MHz square wave, the harmonics are 3,5, 7 etc MHz.
If you LPF a square wave, in the above example say at 2 MHz, ( with lots of attenuation ) then your only left with the 1 MHz fundamental , a sine wave.
How to get back to a square wave ?
there are many techniques of converting a sine wave to a square wave,
https://electronics.stackexchange.com/questions/163253/sine-wave-to-square-wave-schmitt-trigger
https://forum.allaboutcircuits.com/threads/sine-wave-to-square-wave-converter.85771/
https://www.engineersgarage.com/contributions/waveform-converter-circuits/
BUT, note,
you can get nice fast edge square wave, but the mark space ratio tends to not be to good,
the problem tends to be "noise" around the reference point, and or the variability in the window
