LTspice simulation on 4th order active bandpass filter using multiple feedback and Sallen-Key topologies didn't go as I expected
ericgibbs
Joined Jan 29, 2010
21,578
hi,
If you compare the AC response from both stage of your circuit, they are almost identical. 0dB upto approx 1kHz
On the reference plot at 1kHz the response is approx -50dB and at 1Hz it is -170dB.
I appreciate by unloading the 1st stage by disconnecting from the stage will effect the response of the 1st stage, but not to those degrees of attenuation at the lower frequencies,
I would suggest you look at stage 1.
BTW: have you been give the actual written bandpass specifications for the target response
E
Yourint
Joined May 18, 2021
13
hi Y,
I created my own from a the web ,made a Auto Gen model [ not very tidy, but it works]
Used AC as 1v in order to the correct plot.
E
Tidied up..
I think I'm too curious with Sallen-Key ,so I go to check my MFB first then I found out that my MFB isn't done yet.
The bandwidth suppose to be around 10kHz from 10kHz to 20kHz, but in this case, my bandwidth is so large compare to your simulation. Where did I go wrong?
ericgibbs
Joined Jan 29, 2010
21,578
hi,
This is with using a the Old OPA and a High speed OPA,
I have deleted the component values, I cannot give you the answer.
E
Audioguru again
Joined Oct 21, 2019
6,826
The old uA776 opamp has a very low slew rate that kills high audio frequencies, especially at high levels.
Its datasheet has no graphs.
Its weak output current cannot drive (at increased levels) the low resistor values shown in the circuits here.
Yourint
Joined May 18, 2021
13
Please don't mad at me I know I'm bad at this, but I have already read all that you guys have sent and I appreciate that so much. I still stuck on how do I find the value for each component. Do I need to assume one resistor then use it to calculate further? like I can't even get the same simulation as what you had sent or the reference when I just copied the whole circuit. I would like you guys to see me as a complete newbie, hope you guys understand this. Thank you so much (TwT).
I would like to finish my MFB first then I can go on to the next one, so now I stuck with one question. Is the phase change suppose to be 360 when it is 4th order, not 540 (-180 to 360) like in this picture? If I'm not wrong I remember that my teacher once said that the phase change will increase with the order.
ericgibbs
Joined Jan 29, 2010
21,578
hi Y,
No one is getting mad at you,
But I would ask why have you totally ignored the circuit layout configuration I posted in post #25, which works OK..??
E
Yourint
Joined May 18, 2021
13
hi Y,
E
I already build it in my LTspice, I already try to put some value on it, but I don't know how to tune the value ._. to get that beautiful simulation result
38,838
What formula are you using to determine their values?
The values you are using are apparently not correct.
And if you want a bandpass filter the second filter needs to be a low-pass.
Your circuit has two high-pass filters in series.
Audioguru again
Joined Oct 21, 2019
6,826
The uA776 opamp is low power, has a poor high frequency slew rate and has a poor high frequency response. The ST Micro datasheet has no graphs with details about it.
Use a newer and much faster opamp for the 15kHz peak then it will produce a proper high frequency rolloff.
Here is your sim but using a good opamp:
