Help with LTSpice circuit simulation
lindula
Joined Sep 23, 2016
100
I don't know how to configure the Amp setting for I1 to be 1 - (the voltage across C1).
I also don't know how to configure the Amp setting for I2 to be 2 - 2 x (voltage across C1)
I tried using an equation but I'm getting errors.
Can anyone give me some help please.
lindula
Joined Sep 23, 2016
100
I changed the Current Source with a Behavioral Current source and was able to run a sim.
Now I'm trying to get the simulation to show the current and voltage across the C1 cap.
38,912
Below is the correct (I think) simulation of your original circuit:
The inductor, being in series with an ideal current source, has no effect on capacitor current or voltage.
Note the uic (not startup) transient simulation command for proper initial conditions at startup.
eetech00
Joined Jun 8, 2013
4,744
Hello, I'm trying to simulate a homework problem. View attachment 365600
Show the image and text of the problem the instructor gave you.
lindula
Joined Sep 23, 2016
100
Thank you very much.
I will will calculate I(C1) and V(C1) by hand.
Have a great day
