Need Help with LTSpice Circuit Simulation
Bora Fikret Karakütük
Joined Aug 29, 2017
16
I am trying to both learn LTSpice and analyze a circuit that I have designed. However, I haven’t been able to get the expected results from my simulation. I have attached my design file. Could you please help me with this?
Joined Aug 29, 2017
16
Joined Aug 29, 2017
16
Frankly, I don't know much about LTSpice. I'm trying to learn, and since I'm not very familiar with the program and testing my circuit, I can't see my mistakes. It's very difficult to find resources to learn this application in my country.
Hi Bora,
Got the extra downloads OK.
The circuit has a lot of error messages, what is the problem you are seeing on the simulation.
E
ericgibbs
Joined Jan 29, 2010
21,591
Hi Bora,
Can you post a rough description of what you expect the circuit to do?
You have chosen a very difficult circuit to start learning LTSpice.:)
E
Joined Aug 29, 2017
16
Hi Bora,
E
I'm trying to test the compensation portion of the SMS flyback design and its effect on the circuit. I'd like to see if I should use single compensation on the TL431 and UC3842 sides, or if this approach would yield cleaner results.
ericgibbs
Joined Jan 29, 2010
21,591
hi Bora.
The full circuit is too complex to run with all the errors.
One method to debug, is to breakdown the full circuit into working sections.
This plot and circuit show an edited output stage, the modifications are to enable the circuit to simulate, it needs some redesign.
I suggest you debug the full circuit using an asc file for each section and then debug the remaining circuit sections using their own asc file.
E
Joined Aug 29, 2017
16
hi Bora.
E
Thank you very much for your effort..
ronsimpson
Joined Oct 7, 2019
4,840
I don't trust some of the SPICE models on the internet. Try the LT1243, LT1242 parts. They are a little different, but I know they work with LTspice.
The clamp diode should be much faster than the 1N4007.
