Push pull converter simulation in LTSPICE
deelakademel
Joined Mar 10, 2026
15
I'm trying to get a 350V DC output from a 24V supply,but my output doesnt go higher than 24V. Could someone explain where im going wrong. This is the first time im doing something like this.1776742970475.png
ericgibbs
Joined Jan 29, 2010
21,643
Hi dee,
You say you want a 350Vdc output when using a 5R Load, that is 70 Amps.
For a 24Vdc source voltage, at 100% conversion efficiency gives a ratio of 14.5, so the 24V source would have to supply 70A * 14.5 = 1015 Amps.
Recheck your actual circuit requirements.
E
deelakademel
Joined Mar 10, 2026
15
Hi dee,
E
I'm actually trying to design the High voltage DC bus for a pure sine wave inverter, if that makes this any clearer. So this will provide the power rail to the H-bridge for my sine wave inverter. What should I consider when designing this stage? Thank you for the reply.
ericgibbs
Joined Jan 29, 2010
21,643
I'm actually trying to design the High voltage DC bus for a pure sine wave inverter, What should I consider when designing this stage?
hi dee,
You need to specify the required load voltage and current for the project.
Why is it required to be a 'pure sine wave' for a 350Vdc load???
Please post the final full specification.
E
deelakademel
Joined Mar 10, 2026
15
hi dee,
E
Hi ericgibbs,
I need the 350V to reconstruct a 50Hz 230V rms sine wave using SPWM, im using an eg8010 to generate the spwm.
deelakademel
Joined Mar 10, 2026
15
Hi ericgibbs,
As part of our project we are building a pure sine wave inverter.1776795117874.png
Like so, but our input voltage is 24V and output power is 300W
ericgibbs
Joined Jan 29, 2010
21,643
Hi.
I read this TS's quote as he is expecting to 'provide the power rail to the H-bridge'.
This is why I keep asking him for details regarding the current he is requiring to drive this bridge load.
As he has a 5R load on his LTSpice circuit suggests he may think he has designed a power amplifier circuit.!??
E
deelakademel
Joined Mar 10, 2026
15
Then there is loss in the H bridge.
Your batteries can only supply 300W and you want 500W (output power + loss) you need to think about power. Things are not adding up.
Maybe you are thinking 1.3A peak and 0.8A average.
Sorry, I meant my output power should be 300W.
deelakademel
Joined Mar 10, 2026
15
I'm designing a push pull converter to convert 24V to 350V DC. This is to be used for a pure sine wave inverter operating at 230V rms 50Hz with an output power of 300W. This is my first time designing something like this.I'm using the SG3525 to generate the complementary PWM signals to drive the mosfets at a frequency of ~100kHz.
Theres an issue with my output volate and I can't figure out the reason.
X3 drain voltage (Green)
X1 drain voltage (Blue)
Output voltage (Red)
Q. Is my output resistor sized correctly?
