Push pull converter simulation in LTSPICE ..#2
Bordodynov
Joined May 20, 2015
3,435
See. 300 V rectified cannot be obtained with 150‑volt diodes! Also, when the coupling coefficient is less than 1, a high voltage develops across the transistor drain terminals.
28,615
The voltage ratio between input and output of a transformer is close to the turns ratio of the transformer. So to get the 1 : 14 voltage ratio the secondary must have 14 times as many turns as the primary. It is the turns ratio, not the inductance ratio, that matters.
WHAT IS the ratio ppresently?? What is the turns ratio??
