noise analysis comparation of theory and ltspice simulation
yef smith
Joined Aug 2, 2020
1,487
Hello,from page 486 of art of electronics book there is this example I am trying to understand how to optimize the noise of such system.
The transistordatasheet is presented below.photos and full pdf is attached.
In the book they dont describe exactly the inpus source.
Few questions:
1.what source to use in the LTspice simulation?
2.Is there a way to recreate the shot and johnson noise in a table in ltspice as shown below?
https://www.onsemi.com/pdf/datasheet/mmbt5089-d.pdf
yef smith
Joined Aug 2, 2020
1,487
Hello Eric,few questions:
1.How do you define noise source 7 nv/sqrt(Hz) as they say in the book.
2. given the circuit how did you know to choose the following source input?
yef smith
Joined Aug 2, 2020
1,487
Hello Eric, yes its the third video.
In the book example they define "few nv/sqrt(Hz)" noise from the input.
in the example video they dont mention this.
how do I definesource input noise?
Thanks.
ericgibbs
Joined Jan 29, 2010
21,649
hi yef,
I do it by adding series resistance to the Vinput source.Try changing Rser.
Note: I do not have the model for the Book transistor.
E
yef smith
Joined Aug 2, 2020
1,487
Hello ,two questions:
1. a resistor is creating johnson noise which is stable threw the BW.
1.29×10−9V/sqrt(Hz) as shown in the calculation.
why the plot is not stable threw out the all frequencies?
2.given this simple example how do I do Noise figure in ltspice?
Thanks.
yef smith
Joined Aug 2, 2020
1,487
Hello Eric,given the 100ohm resistor creating input noise Is there a way to calculate noise figure in LTspice from the simulation of the circuit ?
Thanks.
0ri0n
Joined Jan 7, 2025
197
Noise Figure [in dB]:
NF = 10 log (Vn² / 4kTRs)
You get Vn², the total input noise power, contributed by the source resistance Rs and the DUT, from the noise simulation (inoise in V²/Hz). 4kTRs is the input noise power due to the source resistance Rs.
I don't know if LTspice can plot the whole formula and give you directly NF as a function of frequency.
