LTspice simulation of RLC discharge circuit using voltage controlled switch
frustratedgrape20
Joined Mar 3, 2020
23
Hi, I would like to simulate the discharge curve of an initially charged photoflash capacitor into a RL load as shown below (with component parasitics):
circuit schematic.jpg​
A few things to note:
1. photoflash capacitor (C1) is initially charged to 360V
2. a voltage controlled switch represents a microcontroller triggered thyristor that turns on exactly 1ms late
When this circuit is simulated, the following graph is obtained:
circuit simulation result.jpg​
The simulation shows a discharge current less than 1nA when around 6kA of current is anticipated. How is this possible?
I have attached a copy of the schematic below.
Thanks!
ericgibbs
Joined Jan 29, 2010
21,649
hi 20,
What is the voltage source charging the capacitor.?
E
Update:
The IC for V(n003) corrected.
frustratedgrape20
Joined Mar 3, 2020
23
Any DC source, such as a battery. I have tried changing the node designation but nothing worked. Would you have any idea of the root cause of this simulation error?
frustratedgrape20
Joined Mar 3, 2020
23
hi ericgibbs, the latest simulation appears to be the result that I was looking for - a shift in the closing time of the equivalent switch; could you upload a copy of that schematic so I may learn what went wrong with mine?
