How do you solve the following dependent circuit problem? I tried to use KVL to get i1, but I got .44, which is the wrong answer.
WBahn
Joined Mar 31, 2012
32,779
I0 = I1 + I3
Smaller circuit for i1: 11 - 62 -19I1 = 0
i1 = -2.68
i3 = 11 - 15I - 2.68 - 9 = 0
i3 = -.045
Several issues.
First, your thread title indicates that you are supposed to use KVL, yet you're working with KCL equations.
Second, your equations use currents that aren't defined in your diagram. What is I0? I have no idea, because you haven't defined it.
Third, you are making mistakes that would be trivially easy to catch if you had tracked your units properly, but because you aren't do so, you don't catch it and then are left wondering why you aren't getting the correct result.
"Smaller circuit for i1: 11 - 62 -19I1 = 0"
should be
(11 V) - (62 Ω) - (19 Ω)(I1) = 0
So you are subtracting a resistance from a voltage. Not physically possible to do that, so you KNOW the equation is wrong right at this point. No need to waste your time going any further until you address this.
mcropper14
Joined Dec 4, 2019
Several issues.
should be
So why is it not:
- (62) ohms - (19 ohms) (i1) = 0, I thought that 62 and 19 were voltage drops.
WBahn
Joined Mar 31, 2012
32,779
So why is it not:
The "62" is from the resistance of R1, which is 62 Ω. Similar for the "19" and R2.
Resistance is NOT a voltage drop. To get the voltage drop, you need to multiply the resistance by the current flowing through that resistance. Review Ohm's Law.
