Battery will be about 8.45v..9v50 ma........why not batteries.
lol..The generator has 2 outputs...speaking of two outputs (thanks)..How to get this?What will you do when you need the generator to drive the circuit that your signal generator is supplying power too?
Don't understand the -15 part unfortunately...Anyways, will try again to understandIt’s the same as positive side just reversed. Follow the diagram. 50mA might be too much.
hehe..Yeah..I am trying to get it from generator then make filter to pick up either the fast or the 1khzYou mean you want that, most of us throw that stuff away.
No..Learning from a book.Is this a homework assignment?
I will use zener then transistor..near constant v and I?What does the book say? Any load on that circuit will drop the voltages... might be ok for a mosfet gate voltage tho...
lol..I know nothing..I tried earlier today, used 3 5.6v zeners and transistor and used 1M ohm as load..5v/div..did not seem to move but looked like ripple : stupid me did not adjust time div to see ripple...OK sounds like you know better... let me know how it goes.
I thought you were looking for a way to amplify a signal from your function generator from 20V to 30V. A cheap, mains-powered audio amp would easily do this for the proper frequency range.Thanks but where will the 30 come from? the extra volts
Yeah I'm trying to power up op amp and transistors that need +-15 dc...needed to use the function generator with capacitors and diodes to get this... I wasn't clear yeah... Yill above provided the solutionI thought you were looking for a way to amplify a signal from your function generator from 20V to 30V. A cheap, mains-powered audio amp would easily do this for the proper frequency range.
Apparently you're doing something else, which I still don't understand.
Are you trying to power some op-amp or other IC that supposedly needs a ±15V power supply? Tell us what you really want to accomplish and what you are starting with.
That's A solution that comes with serious shortcomings, particularly current capacity. If it works for you, fine.Yill above provided the solution
