CD4033 Connections For 0 To 9 Counter
maker_2023
Joined Nov 20, 2023
199
Remember this rule - Leave no input pin not connected. In other words, input pins must be connected to a proper logic level voltage.
Pin-15, CLK is an input pin. What are you going to do with that? Connect it to pin-15 of the previous counter.
Since RST, pin-9 is active HIGH, connect it to GND to disable RST (or connect it to pin-9 of the previous counter).
Thanks. It works perfectly! Now to wire up the other four digits.
M
maker_2023
Joined Nov 20, 2023
199
I have now added a third digit to the counter circuit. As luck would have it, the third digit doesn't
work at all but one and two work fine. I have checked the wiring multiple times and I believe that
it is correct. I swapped out the CD4510, the CD4511 and the display with those in the second stage.
All ICs work. I checked the voltages on CD4511 and they are correct. I have no idea what to do next.
Note: I have disconnected all segments except for "e" so that the photo is easier to view.
Help!
M
eetech00
Joined Jun 8, 2013
4,716
Help!
M
Show a schematic.
sarahMCML
Joined May 11, 2019
703
Here is a schematic for the 2-digit version. The hundreds digit is wired identically
to the tens digit. Pin 1 of the CD4510s is grounded, contrary to what the schematic shows.
I may be wrong, but it looks to me as if pins 1 & 16 on the leftmost counter may not be inserted into the breadboard?
